normal wear for cam bearings? 72k miles
is this normal wear for cam bearings with 72k? I'm in the middle of changing my cam and noticed the wear. thanks in advance.
on the crank i noticed a pattern, is it normal? what is it from?
Jon
Jon
Originally Posted by CW00BlackTA
The main thing is they should be very smooth with no metal transfer from one surface to another.
Jon
Here is a shot of an LS7 cam bearing... prior to the motor even being assembled at the factory. I have seen the same thing several years ago on brand new C5 LS1 and LS6 motors. Note that these motors have their cam bearings line honed after installation... and it does remove surface material... and its no big deal. Key is to check tolerances. If they are within factory specs leave the cam bearings alone... too many horror stories of folks changing them out during a rebuild because the bearings "didn't look right" or "since yer in there"...
Bill
Bill
Originally Posted by GuitsBoy
Perfectly fine. Ive seen 10K mile motors that are showing some copper color. Its normal on these motors.
As for the crank, those are simply machining marks.
Bill
Bill
