View Poll Results: Which cam for best power under the curve and 400rwhp
226/232 .585/.595 109
32
24.06%
228/232 588/592 110
54
40.60%
232/234 .595/.598 112
47
35.34%
Voters: 133. You may not vote on this poll
Poll: which cam for power under curve?
Old 03-25-2007, 11:22 PM
texasheat's Avatar
Default Poll: which cam for power under curve?
I want to know which of these cams you would go with if you wanted at least 400rwhp and a **** load of power under the curve...Please choose and tell me why.
Old 03-26-2007, 01:57 PM
justin quick's Avatar
I voted for the 228/232 cuz im bout to buy it this week. Had a 228 in my other SS and was happy with it but second time around i want more power and figure the the extra duration over the 228 should give me the extra power i want and i shouldnt have to rev it past 6300 or 6500 from what i have read. Also have been told that this cam gives good power down low and really lites up around 3000 rpms and hat with full bolt ons and the stall i have (3200) shouldnt be a problem reaching 400 rwhp with this cam.
Old 03-26-2007, 06:02 PM
brad8266's Avatar
I have a cam similiar to the 232/234, mine is a 232/236 and it has power under the curve way better than a stock cam car. I really like my cam and would recommend it to anyone, it is easy to tune and is very drivable and makes great power.
Old 03-26-2007, 07:37 PM
Ragtop 99's Avatar
I voted for #1. smaller duration and tight LSA. 1 or 2* advance and it will make lots of midrange torque.
Old 03-27-2007, 12:10 AM
Blk97WS6's Avatar
+1, and for the exact reason.
Old 03-27-2007, 09:26 AM
LS1 Tech Administrator
Patrick G's Avatar
This poll is worthless without knowing the intake centerlines (amount of advance). That component is just as critical as the rest. What is ideal for a cam-only application will not be ideal for a higher compression combo with ported heads.
For cam-only, I like 230/230 .612/.604 110LSA +4.
Closest to that is the 228/232 110LSA in the poll.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 03-27-2007, 03:25 PM
texasheat's Avatar
Would this be a good daily driver cam? Lots of miles....How often would springs need to be checked?
Old 03-27-2007, 03:40 PM
Patrick G's Avatar
This cam can be daily driven with a good tune. If you run good dual springs, they should be check once a year or every 12k miles and replaced once pressure drops an average of 5 lbs or more across the board. Some people have gotten 40k miles with these lobes and Patriot/PRC/Manley dual springs.
__________________
Old 03-27-2007, 05:56 PM
ls1builder's Avatar
just did a ms4 install on a c5 i used double srpings form tsp and just used the stock retainers used stock length pushrods if the cam has a 112 lsa u might have to cut the pistons i think that is the rule not for sure i used a 111.5 no interference or clerance issues dont use bolts to put the heads on go ahead and buy arp studs its well worth the extra cash in the long run us the zo6 head gaskets when u go back if your taking ther heads off there the metal ones not the shity *** graphite ones hope all this was helpful
Old 03-30-2007, 11:34 PM
texasheat's Avatar
Why +4? Why not +2?
Old 03-30-2007, 11:39 PM
Jpr5690's Avatar
ms4.....
Old 03-31-2007, 11:18 PM
cowboysfan's Avatar
I went with the first choice, only cause the lsa will bribng power down in the lower rpm range. Patrick G knows his stuff I would listen to what i has to say.
Old 03-31-2007, 11:54 PM
brad8266's Avatar
I run a 232/236 112+0, I make 365 ft-lbs @ 3000 RPM's. That is great under the curve power. I run aftermarket heads that are milled a lot too though, so that helps out some more.
Old 04-01-2007, 09:19 AM
Patrick G's Avatar
Why +4? Why not +2?
Because for a cam-only application, you will gain more power under the curve with more dynamic compression. The +4 helps you more in average power than it gives up in peak power.
The story changes when you run higher static compression. If you are running 11.5:1 SCR, then +2 or even +0 would be better for average power. It's all about balancing dynamic compression and intake valve closing point.
__________________
Old 04-01-2007, 09:54 AM
AU N EGL's Avatar
anyone have dyno charts of cams like these mentioned?
Old 04-01-2007, 02:10 PM
01redws6ta's Avatar
What would the DCR be with the 230/230 .612/.604 110+4 cam with stock heads (all stock internals)? This is a custom grind? Who will make this? Patrick, do you like this better than the 110+4 228/232 cam?
Old 04-01-2007, 03:26 PM
brad8266's Avatar
232/236 112+0, TEa stage 3 heads 57cc's, untuned running in the 10's and 11's AFR the whole run. Proper tuning and it will pick up at least 10 more HP.
At 3000 rpms' its about 365Ft-lbs. Thats really good low end power IMO for a 347
Old 04-01-2007, 03:28 PM
brad8266's Avatar
Cam only you want big advance to have that low end grunt.
Old 04-05-2007, 03:37 PM
DJ_951's Avatar
Buy a cheap set of heads and a MUCH smaller cam and change the springs every 50K. Changing springs every 12k for 400RWHP something is wrong. That's a lot of work. For that kind of work use nos you only need a 100 shot or less.
Old 04-05-2007, 04:39 PM
algws6's Avatar
are those heads 5.3s, 5.7s, or LS6 heads?
Quick Reply: Poll: which cam for power under curve?
