which heads for 224/228 .581 .588 113 lsa cam?!
Originally Posted by CT ITALIAN 1
The edelbrocks were recommended to me by a sponsor but just trying to get some more opinions before I spend $2300...
Oh well here we go....
I am going to recommend AFR205s. Tony Mamo did extensive testing came with a 224/228 XE-R cam as a best fit... it depends on what your goals are though...
I would go with:
-AFR205s milled .024 to 62cc chambers
-.045 Cometics
-and the cam you referenced with no advance... IVC would be 45 @ .050
This would put your DCR at 8.57 and give you a static of 11.2 (assuming you are about .007 out of the hole...)...
JMO
If I were to spend that type of money I would get the ETP 215's or the Trick Flow 215's. GM High Tech tested those heads against several other heads and the other CNC heads tested made more HP & TQ than the Edlebrocks. In fact the Dart 225's as cast heads made just about the same HP.
http://www.gmhightechperformance.com...ylinder_heads/
Race your car!
afr's, etp, edlebrock, are all a good viable choice IMO. There's still something to be said for a good set of 243 castings that are ported by a good porter too. The TFS heads would be a good choice too as long as you don't mind buying a set of roller rockers to go with them, they need the rockers to work right.
