Help!!! No Oil Pressure
I put another cam in my car last night and cranked and oil pressure read at 70 psi. I warmed it up and drove it and come back and it read about 30 psi at idle. It usually reads 40 psi at idle. Today I cranked it and reads 0. Any help appreciated. Im thinking oil pump. Give thoughts and opinions please.
Thanks
Thanks
Originally Posted by 1999ssls1
700 miles on engine. Stock oil pump from ls1 with 94k. I had the gm asa cam.
I did not have the pump off this time. So its not the o ring. The oil sending unit was replaced when I put the 6.0 in. It just done all this overnight. It is reading absolutely 0 oil pressure. I cranked and was running fine and then I seen the oil pressure and cut it off.
HI, as stated above check the oil pressure sending switch. My friends car had a defective one. He would run the car but the gauge always read zero (please dont do that). Also check the pickup o-ring make sure it isnt pinched or just plain worn, it happens. Last but not least check your oil pump, replace it with an LS6. Good luck keep us posted.
