headgasket problem
Old 04-08-2007, 12:02 PM
sampson01's Avatar
Default headgasket problem
well i did a motor swap yester day and i was all excited to crank it over and started to crank it and i had collant shooting coolant out of the radiator ..... my buddy said that it was a head gasket and id need to replace them .... i was wondering how hard it is to swap headgaskets on a motor without dropping the cradle again .... because ive seen it done but i want some info on it beacuse i want my car up and running again ... please help me out thanks
Sampson
Old 04-08-2007, 12:04 PM
brad8266's Avatar
Coolant shooting out of the radiator means there is a leak in the radiator.
Old 04-08-2007, 12:06 PM
sampson01's Avatar
i mean i had the funnel on the top of the cap so i could fill as the thromostat kicked open
Old 04-08-2007, 12:08 PM
brad8266's Avatar
Oh well in that case yeah it could be the headgasket. It isnt difficult to pull the heads while they are in the car, especially if you used head bolts instead of studs. It can be done in a day.
Old 04-08-2007, 12:12 PM
sampson01's Avatar
alright .... it just sucks because i kicked it over and i just puked ... i wanted to head the cam taht i put in in action
Old 04-08-2007, 12:13 PM
brad8266's Avatar
Good luck with it man.
Old 04-08-2007, 12:14 PM
sampson01's Avatar
thanks bro .... open for discussion still
Old 04-08-2007, 01:23 PM
1320 killer's Avatar
I know a lot people are against using cometic gaskets, but I for one have never had a problem using them. Just hang them spray 2 coats of copper on them let dry and install. As long as you tighten the head bolts down to the correct torque and in the correct pattern you should be O.K. If I were you since the heads are off I would order the ARP head studs. If you goto www.ls1howto.com there is a very detailed step bystep process on how to do a head swap. you can use this process to change gaskets also. Good luck
Old 04-08-2007, 01:30 PM
sampson01's Avatar
what do you mean spray 2 coats of copper ...??
Old 04-08-2007, 01:41 PM
brad8266's Avatar
if you are using a set of MLS gaskets there is a copper spray that you can buy, its a copper coating and it helps to seal the gaskets down perfectly, especially if the deck surfaces of the block or heads arent 100% perfect. I sprayed my Cometics with 2 coats of Permatex brand copper spray and I havent had a problem at all with leaks. I would say to spray your gaskets with copper coating twice at least to ensure that you get a good seal.
Old 04-08-2007, 01:47 PM
Zymosis's Avatar
What gaskets did you use?
And its still not hard if studs were used.
Old 04-08-2007, 01:57 PM
sampson01's Avatar
they were stock gaskets .... i guess i just have to start it over again
Old 04-08-2007, 02:03 PM
brad8266's Avatar
Damn those are usually easy to seal down. No copper spray needed with those, just make sure the deck surfaces are clean and flat and torque the heads down the proper way.
Old 04-08-2007, 04:55 PM
Zymosis's Avatar
x2. I was thinking the same thing. I'm surprised they leaked on you.
