Dirty Coolant/Heat Core Cause Misfire?
Old 04-30-2007, 12:56 PM
1BadTA13's Avatar
Default Dirty Coolant/Heat Core Cause Misfire?
i talked to a service guy at my local pontiac garage and he told me that my p0300 misfire code could be caused by dirty/bad coolant or a dirty heat core....any ideas about this?
Old 04-30-2007, 07:44 PM
1BadTA13's Avatar
anyone???...
Old 04-30-2007, 10:22 PM
8a8mfh's Avatar
Either that or you need to wax the car, that will cause a p0300 any day.
Old 05-01-2007, 05:07 AM
mcamarols1's Avatar
naw he needs a new flux capacitor
Old 05-01-2007, 07:15 AM
slow trap's Avatar
that is the first time i have ever heard of dirty coolant possibly causing a missfire,maybe if it was extremely dirty and causing hot spots or causing your motor to overheat but very doubtful.i doubt your coolant is seriously dirty enough to cause any issues. i'd check the o2 sensors,plugs and wires.
Old 05-01-2007, 11:49 AM
1BadTA13's Avatar
if it was an o2 wouldnt my predator pump out an o2 code??? by the way its not just the code im gettin it is def. missin
Old 05-01-2007, 11:52 AM
Blackss99's Avatar
Check the wires if it's missing
Old 05-01-2007, 12:02 PM
1BadTA13's Avatar
not the plug wires....number 5 is definately one of the cyl. thats missing. Switched the coil pack and wires with number 3 which is firing fine, and number 5 still misses. im lost...
Old 05-01-2007, 02:07 PM
slow trap's Avatar
well then i'd pull the plug and take a look at it. now would be a good time to change all the plugs. it could possibly be a bad injector but i'd say more than likely it is a fouled plug.
Old 05-01-2007, 03:06 PM
1BadTA13's Avatar
changed all plugs already.....got tired of it today and took it to the pontiac garage....*** it
