Futral F13 or Torquer 2?
Old 05-03-2007, 09:44 PM
Matt2105's Avatar
Default Futral F13 or Torquer 2?
Futral cam specs are 230/232, .595/.585, on 112 LSA
Torquer 2 specs are 232/234, .595/.598 on a 112 lsa.
The torquer 2 powerband states 1800-6400 RPM while the F13 is 2500-6800 RPMs.
Is there really that much of a difference in the power band? I was leaning towards the torquer 2 as Ive heard nothing but positive things about it but Ive also heard nice numbers from the F13.
Old 05-03-2007, 10:15 PM
Evans752's Avatar
I LOVE my F13 cam from Futral, but I am sure that the Torquer 2 is a nice cam also.
Old 05-04-2007, 07:10 AM
Sigforty's Avatar
The F13 powerband is normally lower than is stated on the site. Most people seem to make peak power around 6500-6600 with the F13. It is a great cam. When I took the plunge I went slightly bigger with the F14, and was very please with my choice. Any Futral cams are good.
Old 05-04-2007, 07:21 AM
Checkmate's Avatar
I loved my F13, great power everywhere.
I'd highly recommend it.
it made 390 uncorrected in 90degree heat(90% humidty)
Old 05-04-2007, 11:34 AM
Likestogofast's Avatar
+1 for the F13. I have been very happy with this cam since the day I got it. I have yet to find something I don't like about it.
Old 05-04-2007, 12:05 PM
LS1rulz's Avatar
Those powerbands aren't even comparable from one manufacturer to the next. I mean, who decides where the powerband starts? I say it starts at 0rpm.
The Futral cams are great grinds. I think they're Cam Motion lobes, aren't they?
Old 05-04-2007, 12:14 PM
GuitsBoy's Avatar
Ive had both cams, but installed heads when I went to the torquer2. I did like my f13, but had was "forced" to upgrade cams. If youve done your research you know what this means.
The powerband is subjective. In the end, youll be hard pressed to tell the two cams apart. If I was going to do it over, Id probably go even bigger than the T2, but it is a nice starter cam.
Old 05-04-2007, 12:35 PM
ProjecT 9's Avatar
HL F13 here
230/232.642.612-110+0
Old 05-04-2007, 12:52 PM
formula001's Avatar
My f13 will be going in next week on thursday Ill let you know how it is.
Old 05-04-2007, 01:05 PM
PREDATOR-Z's Avatar
Between the 2 I like F13 better on cam only.
Old 05-04-2007, 04:22 PM
Sigforty's Avatar
Cam motion only does the grinding the lobes were created and designed by Allan as well as all the other cam specs. Allan just sends Cam motion the CNC package and tells them to grind that cam.
Old 05-04-2007, 04:35 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Originally Posted by ProjecT 9
HL F13 here
There's another option for you too.
Old 05-04-2007, 10:13 PM
SSNISTR's Avatar
F13.
Old 05-29-2007, 11:38 PM
SVTlightning87's Avatar
do people like the F series cams better because of the cam motion lobes?
Old 05-30-2007, 10:35 AM
seth webster's Avatar
Go with the T2
Old 05-30-2007, 03:51 PM
Sigforty's Avatar
I like them because of Allan's lobes. He designs all the lobes for all of his cams. They are only ground by cam motion, but it is a Futral lobe. for his high lift stuff he has to send them the CNC file to make the cam.
Old 05-30-2007, 05:37 PM
Detoxx03's Avatar
I would recommend a Futral cam over anything.
Old 05-30-2007, 07:39 PM
ELDIABLO's Avatar
I have the TQ v2 and I think both cams are good. My buddy had the F13 and we were dead even when we raced. Both were cam and boltons cars.
Old 05-30-2007, 09:56 PM
99LS1T/A's Avatar
I realy like my F13.. Here is a vid: http://s132.photobucket.com/albums/q...t=HPIM0571.flv
Old 05-30-2007, 10:02 PM
Matt2105's Avatar
That sounds killer. What numbers did you put down?
Quick Reply: Futral F13 or Torquer 2?
