ms3 on a blower...or good blower cam?
well i hate to say it but im building my car right now with a h/c/n setup but it looks like there is just too many cars around me this year that came out too fast.
i was going to buy the ms3 and run that on the n20 but i was wondering how that would do on a basic vortech setup?
LS1 Tech Administrator
Here's a nice comparison of heads/cam/nitrous vs. heads/cam/blower: https://ls1tech.com/forums/dynamometer-results-comparisons/712469-346-afr-205-trak-cam-fast-90-90-p-1sc-results.html
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
any difference in cam selection from blower to turbo?
A turbo will typically want a single pattern cam or even a slight reverse split (depending on exhaust arrangement) with duration in the low to mid 220s and an LSA between 115-116. You'll want dynamic compression between 6.5-7.0:1. On a roots blower, you'll need to really watch the overlap because the low rpm boost is much higher. Keep overlap under 0 degrees at .050" and DCR between 6.5-7.0:1.
With a procharger, you can go with a little more DCR and a little bit more overlap since the boost comes on stronger at higher rpm. You can go 7.0-7.5:1 in dynamic compression and can run your overlap slightly above 0 degrees at .050" if you like.
Honestly, a stock '02 Z06 cam works great on either type of supercharger, but it's not a great turbo cam. A custom cam would gain even more though.
__________________
