Weird Noise On COLD Start
i have a 228/232 cam in my car, i jsut recently developed a weird noise on a cold start. And by cold start i mean my car is not a DD so it can sit for 2 weeks on end. But anyways when i start the car i have great oil pressure. I would guess around 60 - 70 psi. If you were to pop the hood, stand on the passanger side and give the car some gas with the TB you can hear it make this noise. this noise sounds like a baby chick when they are born. it is like a sort of high pitch chriping sound. at idle it is BARELY present. But when you give some gas with the TB the sound rev matches the RPMs......
Here is the kicker. once the car is warmed up. Which takes about 5 mins, the chirping sound goes away!
I initally thought that the lifter leaked out, needed more oil to it. Could it be a lifter? Could it be a PR?
What are your guy's thoughts??
Thanks
-Jonas
Thanks
-Jonas
Originally Posted by 1BADAIR
dirt, grease, glazed belt
i barley drive my car, wasehd my water 2nd to last week in April so i am almost certain that it is clean. Belt is brad new. i put it on in Feb when i did my cam. Went with good year gator back....
thanks
Originally Posted by Michael02hawk
I had belt chirp with my gatorback belts, brand new, when i installed the 25% balancer. it drive my CRAZY! i swapped out those belts for a set of gates - its been quite ever since.
do you have a link where to get these belts at? Why is it doing it now? If it makes a difference i also have an ASP pulleye
Originally Posted by TORCHD 02 TA
what does the soap do?
I would as well change the belts to gates. that what we use on the helicopters I work on and only use those on my car. figured aviation uses them why not on my car. goodyear and bando would make noise on my H/C WS6, dont have that problem anymore....
Originally Posted by cowboysfan
works like a lube, soap has oil in it.
where can i get the gates belt from?
So you guys think that my problem is then belt, and maybe nothing internally?
mine started doing the same thing, i've changed the belt, tensioner, idler, and alternator (for other reasons) and it still makes the noise, goes away when the car is warm. i am not running an AC belt. cant figure this out, i've even ran sandpaper on the belt a little and it didnt change...
EDIT: what the hell, the soap fixed it, for a little bit, whats the permanent fix?
you have the exact same noise? When you used the soap, what side of the belt did you apply it too? The smooth side or the side the grooves? Basically top of belt or bottom?
