Trickflow Heads Question
Old 05-31-2007, 08:34 PM
nightmarevette's Avatar
Default Trickflow Heads Question
Alright I got a 04 z06 with ms4 cam, Kooks Long Tubes, Intake, UD pulley, and tune. I would like to get a set of Trickflows. My question is should I have the head milled? What would be the absolute best gaskets I could go with? Im looking to get the most rwhp/rwtq out of these heads so if milling is necessary I wont mind. Thanks for your help!
Old 05-31-2007, 09:07 PM
ls2 bait's Avatar
u prob wont be able to mill much more than maybe .015 without having to flycut which is where u are going to have the problem. they have a diff valve angle than a stock head so u would need to use the tfs head to mill and u dont want to do that as u can ruin the head. thats on a stock gasket.
Old 05-31-2007, 09:24 PM
Killer_Bluebird's Avatar
I'm interested on an answer also. So I can start planning for next year.
Old 05-31-2007, 09:47 PM
Are you looking at a performance gain with miling?
Old 05-31-2007, 10:33 PM
DONAIMIAN's Avatar
Thats the only reason you would mill heads unless the surfaces were damaged
Old 06-01-2007, 11:26 AM
99C5JA's Avatar
I had mine milled to 61cc which I was told retained stock piston to valve clearances. I could have went 59cc to bump up the compression more, but decided it just wasn't worth the worry.
Old 06-01-2007, 12:42 PM
teke184's Avatar
where and how much was it to have them milled?
Old 06-04-2007, 09:53 AM
99C5JA's Avatar
I ordered them through SpeedInc that way. The milling was added on to the purchase price and was done at TFS (extra $150 I believe).
