Crane lifter preload?
Ok, check my work here. I've seen a few threads lately that have me scared.
I installed the cam dot to dot (advance ground into cam), and rotated the motor 'till the #1 exhaust valve was all the way open. At this point, the cam sprocket dot was at about 3:30 position and the intake valve was totally closed.
I put the pushrod checker in on the #1 intake valve and adjusted it 'till the intake rocker barely had no play in it (up and down on the valve stem).
Now the checker has 14.7 turns out @.050" each. Closed it's 6.8" long, which gives me .735 + 6.8 = 7.535"
This would mean that I need a 7.615 to 7.635 pushrod for a .080 to .100 preload correct? The car has not run since Sunday (6/16), started tearing it down yesterday for the swap. Does any of that matter? What is it you mean by hot?
Well I'm using an iron block with Jesel SS rockers.
I have a set of 7.6" pushrods sitting here from my last cam (cam motion). New cam is a comp with XFI/XE-R lobes. If I threw in the 7.6" pushrods, I'd have a .065 preload, which would probably be awfully noisy right?
