GM SER-912 spring compressor tool
Old 05-07-2003, 03:59 PM
robertbartsch's Avatar
Default GM SER-912 spring compressor tool
Where do I buy this valve spring compressor tool - a GM dealer?
This is the tool that looks like a bent steel bar with a whole in it for the rocker bolt....Apparently, the tool works great for $15...
I'm trying to swap out some STOUT double springs and it is not easy...
Old 05-07-2003, 05:58 PM
The Bull
DERTY's Avatar
Default Re: GM SER-912 spring compressor tool
Goto Napa and get one. It's fifteen bucks and you can find it on the shelf usually. It's a black bar about 2" wide and 9" tall sort of L shaped. It has a notch at the bottom and a hole for the rocker arm bolt. It works like a charm. If you need to get under the cowl, just cut the bar down to about 3" tall and it will fit and work fine.
Quick Reply: GM SER-912 spring compressor tool
