Valve spring seat pressure
I think you will find your installed height is not 1.8, but less than that. You asked about the seat pressure, installed height and spring values can be used to compute the installed pressure. What I was saying was the off head spring measurements I have taken conformed very well to the advertised values so that a height micrometer to measure installed height would give you a pretty accurate measurement of the seat pressure.
LS1TECH & Trucks Sponsor
Keep in mind that after so many miles, RPM, etc that valve springs can lose their pressure...and those formulas go out the window somewhat...there is a tool/machine that can test them. If I recall correctly, you can send them to ThunderRacing and they can test them for you (don't quote me on that, you might call them to check).
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
