Cold Start Up Noise
I didn't hear it in the vid, but try the drive belts. Spray a little wd-40 on them when the are making the noise. If it goes aways there you go. Lapping compound works great to get rid of it for good. Just a little dab.
Originally Posted by warp_6
I didn't hear it in the vid, but try the drive belts. Spray a little wd-40 on them when the are making the noise. If it goes aways there you go. Lapping compoud works great to get rid of it for good. Just a little dab.
it starts at 1 minuets, ignore the exhaust and you can hear the high pitch chirp sound
Heard it. Try the belts. Spray them while it's running and making the noise. If it goes away thats your problem. I had a similar noise (a little more severe) and that was it. The lapping compound got rid of it for good. Easy to check. If that doesn't take car of it you can remove the drive belts and fire it up, see if it goes away. That way you eliminate all the accessories.
ok i will try the WD40... only a little bit though... the belts are new. put them on in February. I put on Gatorbacks.....
Glad you heard what i was hearing...
Thanks
