How do I remove my crank sprocket?
Three jaw puller. Just went through the same thing. The puller I had would not work the jaws were too thick. Went to Autozone and the puller they had in stock worked perfect. Good luck!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Damn; the one I'm using is from Auto Zone and the jaws keep sliding out from behind the teeth! ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Also, how did you get the new one back on?
Originally Posted by Halloran
Use the law of thermal dynamics. Once you get the sprocket off and you need to put it back on just put it in your oven for about 20 minutes at 400 degrees. Metal expands...this is what I did with mine. Once it's nice and hot take it out on a tray and use an oven mit. Have a friend or someone just put some oil on the sprocket shaft and slide the baby back on. You may have to use a LIGHT tap of a rubber mallet or so to put it back on all the way but mine went on easy as pie. Hope that helps ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
no need for that, just slide the new sprocket on and then slide your old one on and tap it with a hammer. The old sprocket wont go on far enough to catch and will very very easily seat your new sprocket all the way. You don't even need to tap very hard. I just finished installing my rollmaster saterday.
