HELP!!!! New 383 Stroker NO OIL PRESSURE!!!
Hey Guys,
I'm not a bad mechanic but this one has me stumped. 2002 Mallett Hammer Corvette Z06. Swapped out my blown up 5.7L for a new 383 (Stroked 2004 style LS6) short block. Swapped everything over... installed it and fired it up. It runs fine but there's NO oil pressure what so ever. I've done this about 4 times all together running the motor for 10-60 seconds each time. This is what I've checked so far.
Oil level is fine.
Installed a new oil pressure sensor... (the sensor on the the back of the motor next to the cam sensor)
...no change still 0 pressure.
Got a manual oil pressure gauge to hook up to the front oil galley port but its not metric thread so its worthless.
Took off the oil filter and it sprays out oil when it's cranked.
Dumped oil into the Oil Pressure Sensor hole... (Last ditch effort)... still nothing
The gauges go through their "warm up" when the ignition just fine so I'm guessing the guage has power.
Is the pump cavitating... does it need primed.
I'm pretty sure that all my grounds are hooked up. Was getting some B2500 trouble codes for a bunch of random **** like turn signals and back up lights but I just cleared them.
Please help me out guys!!!
Rick
If you're an expert and have fixed this before give me a ring.
330-391-1454
Oil level is fine.
Rick
330-391-1454
Tenured Member
When you put the engine together did you check to see if the front core plug is in. You have to pull the timming cover off and its right behind the oil pump. On the driver side front.
I looked at my old block and I think I found the plug that you're talking about. Honestly I'm not sure whether my new block had one or not. I'll talk to my short block builder and see if it came with it because it obviously didn't get switched over from the old one. If that's the case then I'm glad that I might have found the problem... unfortunately I'll have to rip the entire front of the damn engine apart to get at it... oh yea... and I've got a Vette so I'll have to lift the engine up to get the harmonic dampner off... I'll keep the thread updated.
Rick
Rick
someone had the same exact problem like 4 months ago....i think it was on ls1.com..... try looking under the camaro section there.....and they solved it i believe...something aobut porting the block...well its better if you look
Rick
Rick
Either of these (missing) will net zero oil pressure.
Also dont overlook the O-ring for the oil pump. Just dealt with this on a friends truck durring a heads cam swap and instead of low oil pressure like whats common with more pinched O-rings, he had absolutly nothing.
yea i would check the oil galley plugs... i missed the rear one on my old car w/ a 402.
it sucked...
but also check the o-ring on the oil pump. that's a simple fix. they get pinched or twisted and obviously doesn't provide a sufficient seal.
it sucked...
the rear oil galley plug
which goes here. this required me removing the trans again.
goes in like this
then there's a front 15.68mm plug that goes in the front side of the oil galley.
goes in like this
holy **** i almost **** myself readin this thread cuz i just put my 408 in and didnt check for those. i ordered 2 408's ( same company/engine builder)i looked at the one thats gonna go in my friends car and it had the plugs praise the lord!
Originally Posted by Bo White
The other 408 does too? Need to check , let me know how the TB does
