For those with 402ci Builds in a F-body
I recently talked to a guy and he said that a friend of his built a 402 with Eagle 4.000" Crank, Eagle 6.125" Rods, and one of the Rod Bolts scuffs on the Oil Pan where the little curve in it is. This is with the F-body Oil Pan.
Anyone else have this happen to them, or heard of it?
Yes, they will hit with a 4 inch crank. turn the motor over til the front crank journal is at its lowest point. measure with a straight edge and ruler. I believe the measurement is 1.25 roughly. Then measure the pan the same way. I wanna say that measurement is just over an inch deep. Add the thickness of the gasket in, and you come up about a 1/8 inch too short, or too close.
I grind the corners off the rod bolts, and clearance the pan a little.
I've built a few of them, any other questions, post or PM, I'd be glad to help.
Jeez, merv, 5000 posts since last year? Do you ever sleep?
I try sleep every now and then..it's over-rated..
Right now I have nothing to work on..the Rotating Assembly is at the Machine Shop getting Balanced. Looks like I have to clearance the Pan tomorrow..hopefully there is enough there to work with. Personally I won't grind on any Bolts.
Then I got to get the Throttle Linkage setup for the Swap..I am making an Adjustable Cable.
I got the ESP Series H-Beam Rods..from what it looks like that is the only spot where I have a problem, every where else clears.
Is that from the Pan, or the Bolt. Personally I'm tryin to not alter the Bolts in any way..
I have some scrap 1/16" Aluminum sheet here, I can grind the Pan and hopefully get ahold of a Welder here to patch it up if need be. That will probalby be the best way.
I wonder if you double the Gasket if that will help..might mess with the Pickup though..
Grinding the bolt heads is no big deal, really. You're only taking off a little of the corner of the head. you wont even heat it up much.
Like I said before, on the I beam rods in strokers, you have to grind the **** out of em to clear the cam.
