Hot Cam, do I need new push rods ?
Old 07-21-2007, 08:49 PM
99SSragtop's Avatar
Default Hot Cam, do I need new push rods ?
Will I need longer push rods if I install a Hot Cam or stock is fine? Stock rocker arms will be used.
Thanks
Old 07-21-2007, 09:43 PM
2000TransAmWS6's Avatar
nope, stock length is fine
Old 07-21-2007, 10:04 PM
BerryWS6's Avatar
I used stock pushrods with the HotCam when I had it
Old 07-22-2007, 06:43 AM
99SSragtop's Avatar
Will the Hot cam pass emissions if tuned? Thanks.............
Old 07-22-2007, 07:15 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It should.
Old 07-28-2007, 09:25 PM
99SSragtop's Avatar
My tuner is saying it maybe hard with the 112 to get it to pass emissions.Rrrrrr
Old 07-29-2007, 09:55 AM
litle88's Avatar
Dont know about those french laws oops I meant canadian but I am going tomorrow for my emissions test, I already got my rear o2's and air pump deleted! I'll keep you posted.
Old 07-29-2007, 08:39 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most of the time: A cam that is below 230 duration will pass. Hard to speak for a different country's emissions testing though.
Old 07-29-2007, 08:48 PM
litle88's Avatar
Sorry I forgot to mention, you should change them since your going in to change the springs. I got my chromoly Pr's at speedinc for less than 100 US dollars. Very good insurance and you will see the difference when you compare them side by side.
Old 07-29-2007, 09:53 PM
99SSragtop's Avatar
Keep me posted and if you can post your results from your test. Our test is the old rod slammed up the pipe test....
Old 07-30-2007, 07:18 PM
litle88's Avatar
Well I just passed the `TEST` here in Illinois we don't get anything up our pipes LOL all they did was attach their cable to the OBD II diagnostic port and run a test but luckly I had a tune at straight line perf and they deleted the rear o2`s, air return and the skip shift! good luck with ur cam and keep ME posted
Old 07-30-2007, 07:34 PM
Scammer Alert!
Ricks99ls1's Avatar
i already have instaled some comp chrome moly pushrods, could i just do some springs and install, or do i really need the ls2 timing chain? not to hijack, but i am also looking at a hot cam
Old 07-30-2007, 08:38 PM
99SSragtop's Avatar
I need to know if someone has had the sniffer test and has passed.....
Old 07-30-2007, 08:43 PM
White_Ls1's Avatar
My guy at chevy told me the ls1, ls6 and ls2 timing chains are all the same. ie same part number. Might as well since you are in there and oil pump too.
Old 07-30-2007, 09:41 PM
litle88's Avatar
Sorry but ur chevy guy is wrong, the LS2 timing chain fits the LS1 sprockets but they are CLEARLY different LS2 is thicker, w/different part numbers. So yea please upgrade!!
Old 07-31-2007, 12:54 AM
White_Ls1's Avatar
Good Info!
Old 07-31-2007, 01:07 AM
Tainted's Avatar
go with something stronger than stock
Old 07-31-2007, 01:36 PM
litle88's Avatar
An Ls2 chain is stronger than an LS1, slip right in with no problem. And is good for a hotcam installation. Dont you think so chuck!
Old 07-31-2007, 03:13 PM
blkbird's Avatar
I used the LS2 chain for my hotcam install. Its definately beefier than stock....
Old 07-31-2007, 08:53 PM
Hennytime's Avatar
stockers are fine, kp ran them at 6800rpm on a d1sc running 9s. you shouldnt be spinning a hotcam over 6400rpms so stockers will be fine, if your really concerned, roll them on a piece of glass, that will tell you if they are already bent or not
