what the hell happened to my main bearings?
Old 07-26-2007, 08:09 AM
lmt0705's Avatar
Default what the hell happened to my main bearings?
I was at the track over the weekend and after the last couple of runs and on the ride home i noticed my oil pressure was lower than normal and when I cracked the throttle the pressure dropped. I changed the oil and cut the filter up and sure enough there were tons of copper shavings. I pulled the motor down and found that my thrust bearing and the one in front of it were fu--ing fried. the cap side of the bearing was actually cracked!! and they all looked like they were heated. the rod bearings looked decent and the motor dident make any noise. I was playing around with crankcase ventalation at the track. and my oil was 5/30 with around 3000 on it. did I boost the crankcase and lift all the oil? maybe I twisted the mains? Im running arp studs and the berrings were clevite 77s. the shops I talked to were puzzled that I had this problem at my horsepower level.
Old 07-26-2007, 08:12 AM
lmt0705's Avatar
the line bore was out .001-.0015 im still waiting to hear about the crank
Old 07-26-2007, 10:27 AM
WMSuperSport's Avatar
wow. keep us posted. who built the motor?
Old 07-26-2007, 03:14 PM
lmt0705's Avatar
i did, it had too many miles on it to be the build to be that I think, no one seems to have a straight answer for me
Old 07-26-2007, 03:47 PM
LS1curious's Avatar
pictures of bearings and crank ?
Old 07-26-2007, 04:01 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Sounds like an interesting problem. on the pictures.
Old 07-26-2007, 05:39 PM
lmt0705's Avatar
ill see what I can do, my machine shop has the bearings right now because they were all awe struck as well and wanted to ask around. anyone else have any ideas what happened?
Old 07-26-2007, 08:41 PM
OWN3D BY MY PROF!
Improper torquing of the main bolts?
Old 07-27-2007, 12:33 AM
tahoe's Avatar
I remeber reading a few threads about the same problem, fried thrust bearings.
I don´have the time now to do the search for yo, bu it´s here.
Old 07-27-2007, 12:39 AM
GOaT Cheese's Avatar
If it were an A4 I would suggest inspecting the torque converter for "balooning".
