Cam on Stock Manifolds?..
Old 08-01-2007, 01:25 AM
LS1Silverado05's Avatar
Default Cam on Stock Manifolds?..
Ok...I have been having more and more of a tapping sound inside the motor...Im thinking it may be a lifter issue....so...that said, will I be ok with a cam on stock manifolds for a while?..I know LTs will bring out the power, but will I be ok until I get some?.
Old 08-01-2007, 01:40 AM
|2ocky's Avatar
I don't know why it would hurt the car, but what does that have to do with a lifter issue?
Old 08-01-2007, 02:59 PM
If I tear down for the lifter I will cam it at the same time..thats why I asked.
Old 08-01-2007, 03:25 PM
Eurospec2's Avatar
Might as well do heads to
Old 08-01-2007, 03:59 PM
Redlinez's Avatar
I did that on my first 99 Z, but what a difference lt's make, but at least you'll get to enjoy the idle.
Old 08-01-2007, 04:34 PM
formula001's Avatar
Yeah you can do it but you will be choking it let that baby breath.
Old 08-01-2007, 07:15 PM
z28ss4me's Avatar
Just installed my TR224 with stock heads and stock manifolds (I'm in Cali so long tubes just aren't a legal option). I should be going to the track next wednesday to see how it performs. I'm really hoping to pickup 3 tenths, but if I only get a tenth and half to two tenths, I'll be content considering I haven't even tuned it yet. If I don't pick up anything I'll be a bit disappointed to say the least.
Old 08-01-2007, 07:28 PM
sroach20's Avatar
im running a cam 224/230 .585 .592 114 in an lq4 in an 01 z28. it really hauls a$$.
Old 08-02-2007, 01:00 PM
Im not asking if I can leave the stock manifolds for good...I will be getting LTs next mod after the cam but it could be a couple months time..
Old 08-02-2007, 01:03 PM
02silvaZ's Avatar
it will run fine
Old 08-02-2007, 04:39 PM
rickyracer25's Avatar
99-TR-CHEATR-CAM Thunder Racing Custom Camshaft
"CheaTR" - 214/230 .601/.575 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
99-TR-CHEATRLS2-CAM Thunder Racing Custom Camshaft
"LS2 CheaTR" - 215/230 .629/.592 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Comp 921 Valve Springs are highly recommended.
http://www.thunderracing.com
