cam w/out tune ??
Old 08-05-2007, 08:02 PM
transam45's Avatar
Exclamation cam w/out tune ??
i just got a cam from to put in my ls1 and was wondering if i could do it with out tunning i was looking on ls1howtwo.com and they said certain cams do not need tunning to run the car here the stats of mine
Lobe lift:
0.326" I
0.568" E
Valve lift (1.7 rocker):
0.554" I
0.580'' E
Valve lift (1.8 rocker):
0.587" I
0.601" E
Advertised (total) duration at 0.006":
261° I
277° E
Duration at 0.050":
208° I
224° E
Lobe separation angle (LSA):
117
Old 08-05-2007, 09:24 PM
Trev_SS's Avatar
hey man that thing looks like a beast in the phot in your sig, all jacked up like that in the driveway with oil everywhere underthere
Old 08-05-2007, 09:32 PM
delsold's Avatar
ya i think the oil is supposed to go into the engine...not under the car? haha just kidding
but that cam should be fine on stock tuning with such a wide lsa and low duration. is the car an automatic or manual?
Old 08-05-2007, 09:49 PM
transam45's Avatar
its a a4
Old 08-05-2007, 09:51 PM
transam45's Avatar
how many hp you think ill pick with this and can i just use the yellow zo6 springs ? or do i need better ones ?
Old 08-05-2007, 11:41 PM
mxmccarter2401's Avatar
i think ls6 springs are good to 580. so pushin it with the 1.7's and not a good idea with the 1.8's. just get some comp 918's. That looks like a nitrous cam with the larger exhaust numbers.
Old 08-06-2007, 12:30 AM
0utLawZ28's Avatar
it kinda looks like a turbo cam i thought since it had wide lsa and larger exhaust ?
Old 08-06-2007, 01:49 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I ran untuned on a 222/226 566/569 114 for a year. Didnt really seem different after one either.
Old 08-06-2007, 07:26 AM
juiSSed1172's Avatar
I'm currently running an untuned ms4. That cam would run like stock to me.
Old 08-06-2007, 12:00 PM
transam45's Avatar
will this cam make the valves hit the piston ?
Old 08-06-2007, 12:15 PM
1999ssls1's Avatar
No, It definately should be ok.
Old 08-06-2007, 12:16 PM
slt200mph's Avatar
NO way will you have anmy P to V clearance problems.. it is a baby cam and should run OK with stock tune ..
Old 08-06-2007, 12:23 PM
5_02ls1's Avatar
yeah looks like a f.i. cam...id say 25 to 30rwhp...the springs are fine......
Old 08-06-2007, 01:51 PM
radkon's Avatar
While a tune is not essential you may be leaving some performance or mileage on the table without it.
Old 08-06-2007, 04:51 PM
transam45's Avatar
should i ge a bigger cam ? then and if so hat and how much ?
Old 08-06-2007, 05:11 PM
Moderator
davered00ss's Avatar
My car ran fine with the TR224 cam before it was tuned. I just did not get a lot of power before it was tuned. That cam should be fine to drive for a while without a tune, but I would get one ASAP.
As for the springs, don't take the chance. Get some 918's. If you're on a budget, buy some used ones.
