228r or V2
Old 08-08-2007, 09:55 PM
1slow98Z28's Avatar
Default 228r or V2
Just wondering people opioions on these 2 cams. Ive read alot on the V2 and like it. But right now i only have a 2400 stall and i talked to tsp and they said i can run the 228r. Just wondering if i did get the 228r would i want i regret it and should of went wiht the V2?? CAuse if i will make atleast 15+ more rwhp with the V2 i will upgrade my stall but if not i won't.
Also wondering what heads people are running with these cams i was considering PRC 5.3l 2.5 , PRC Ls6 stage 2 or the Livernios stage 2.
i want to be over 400rwhp and make it into the 11 or very very low 12's right now its a high 12 sec car with just bolt ons and on street tires and im only making 316rwhp on a md.
Old 08-08-2007, 09:59 PM
bastien's Avatar
I dyno'ed almost 400rwhp with the V2, full bolt-ons.
Old 08-08-2007, 10:13 PM
navyblueSS's Avatar
My car dyno'ed 400rwhp and 375rwtq with the 228R cam. Thats without an underdrive crank pulley. Very nice cam.
Old 08-09-2007, 06:53 AM
KY Z28's Avatar
I dynoed 420 with the TV2 and PRC LS6 stage 1 heads...and I dont even have a crank pulley
Car pulls HARD and makes good torque
Old 08-09-2007, 02:16 PM
1slow98Z28's Avatar
soo what you think i should do keep my current stall and do heads and the 228r OR do the V2 and bigger stall and then wait for a while on heads??? i just don't want to get the 228r and be like i don't like it i should of went bigger
Old 08-09-2007, 05:11 PM
DaveX's Avatar
228 isn't a "small" cam. It's a nice medium cam and will make good power under the curve. Good way to go I think.
Old 08-11-2007, 10:11 PM
1slow98Z28's Avatar
bump... anymore input
Old 08-12-2007, 01:29 AM
MM98's Avatar
I'd say the 228r would be the better all around cam... Better power down low with enough lift to pull hard up top.. Should have better street manners as well.
Old 08-12-2007, 01:50 AM
BayAreaSS's Avatar
I've been looking at both of this cams. I think i would get the 228r and keep your stall. A 228R with a set of heads would be very strong.
Old 08-12-2007, 08:10 AM
PBMFIsMe's Avatar
+1 on the 228R
I have the V2 on a 3600 stalled auto and while the peak HP is nice (410+) the TQ is a little low (350)
I'm definitely considering a different ("Smaller") cam like the 228R. I have a friend with a 224R that out runs me consisitently at the track and I have a UD Pulley and FAST90/90 that he doesn't. - All of our other mods are identical.
Old 08-12-2007, 09:11 AM
Eddie 70's Avatar
Originally Posted by PBMFIsMe
+1 on the 228R
Very interesting info right there. Does anyone know where to see some dyno graphs with the 224R and 228R cams? I would like to see some comparisons o those two cams. I would like to get close to 400 RWHP but not give up all the torque just to get there.
Old 08-12-2007, 02:29 PM
1slow98Z28's Avatar
ditto on the graph.... how bout any videos to hear it i check in the video o nhere already and theres nuttin good from behind a car...theres a gto one from behind but they sounds different than a F body
Old 08-12-2007, 04:09 PM
maplered ls1's Avatar
I have the tsp 228/228 112 a4 3600 stall with 373 gears,car put down 372 rwhp cam only.Great daily driver cam with loads of power down low as is up top.No sound clips yet but car sounds mean.
Old 08-13-2007, 12:01 AM
monaro's Avatar
Can i use the 228R with the stock coverter?
The car will be DD
Old 08-13-2007, 12:39 AM
red_ryderSS's Avatar
vouch for the 228 cam. dyno numbers and other major bolt ons in my sig. no ud pulley or ewp. i'll try and post a sound clip tonight.
Old 08-13-2007, 05:58 PM
Raise's Avatar
i have the tsp stage 2.5 5.3L heads with the 228r and its a VERY strong cam. it has the street manners of a 224 cam with a significantly harder pull. id go with the 228r with that stall.
Old 08-13-2007, 10:16 PM
1slow98Z28's Avatar
what kind of #'s you run in the !/4 with it and dyno #'s
Old 08-14-2007, 08:12 AM
Raise's Avatar
still tweeking the tune to make it just right, so ill have numbers and track times soon
Old 08-14-2007, 04:23 PM
AK's WS6's Avatar
I'd forshure go the cam and new stall route. A Yank SS3600 would be great with either one of those cams. Plus I think ypu'd get better results at the track with that combo vs keeping your current stall and getting heads.
Old 08-20-2007, 03:15 AM
monaro's Avatar
Planning to get the 228R and use it with the stock stall couse' i dont got the track and all my racecs are 25+ miles rolling
Also I'm getting the PRC springs
