car spits and sputters under a load helpppppp
so my car just stared doin this after i took her to the track
it will drive fine 20% throttle or less. itll crusin down highway no problem.
when given gas it wil pop and ping and just throw smoke out of exhaust.
mods are in signature.
any suggestions or ideas are welcome.
i reset my ses light for a 02 sensors 20 miles ago and light has come back on yet. but i dont know if everything reset itself yet.
sooo
HELLLLPPPPPPPPPPPPPPP
sooo
I had the same problem & mine spit out honeycomb pcs of the cat out the exhaust due to the 1 cat. conv. being bad. Might be the problem or another issue I had happen is I broke a pushrod due to the RPM's gettin' above 6250 (the # where LS1's bend pushrods says Comp Cams). Basically, I dumped the clutch in 1st, fish-tailed up to around 6300rpm & after I let off, the car struggled/sputtered upon accelerating & sounded like a WRX with exhaust best I can describe it. Then, the SES light came on, flashed, then stayed on & as of Sunday, I found the pushrod (2 pcs) laying above the piston, so I'm lucky it didn't enter the engine. I hope this helps & good luck with the car repair.
i went and put 20$ of new gas in it and it runs fine now. i stopped at some local weird gas station on the way home to get gas. they musta had some bad gas or somthing
