what is the best oil pump??
Old 08-17-2007, 08:18 AM
rpmauto's Avatar
Default what is the best oil pump??
was wondering what everybody is running for a pump, and also what balancer is a good one? Is a stock ls2 or 6 pump adequate? I only plan on spinning around 6500 rpm.
Old 08-17-2007, 08:40 AM
11Second Club
Gauge's Avatar
My vote is for Melling.
Old 08-17-2007, 09:16 AM
bsf
bsf's Avatar
I am not certain which is “best”. I installed an LS6 pump (~$80 shipped) I ported and shimmed.
Old 08-17-2007, 10:17 AM
litle88's Avatar
I vote melling!
I love my slightly high oil pressure!
Old 08-17-2007, 10:36 AM
maplered ls1's Avatar
SLP heavy duty oil pump great oil pressure,same oil pump speed inc uses on their stroker packages.
Old 08-17-2007, 12:46 PM
JPH
JPH's Avatar
did someone say melling? lol they got my vote.
Old 08-17-2007, 01:18 PM
tylerdj's Avatar
Most common is probably a ported ls6 pump.
Old 08-17-2007, 01:19 PM
SLO98Z's Avatar
A stock LS6 pump is plenty for most
Old 08-17-2007, 01:23 PM
1CAMWNDR's Avatar
Melling. +10 psi, +15% volume over stock. Costs less than the SLP ported stocker too .
Old 08-17-2007, 01:31 PM
rpmauto's Avatar
i saw on speed incs website that if you use the slp pump with a asp balancer you have to modify the balancer, is this right. Does the melling pump matter what balancer you use?? i have not bought a balancer yet, just curious. on another note the engine i just got when i pulled it out of the crate i noticed that the end of the crank snout was messed up so i called the guy and he said he peens all of them or the aftermarket balancers have a tendancy to walk. dont know if it will hurt anything, just a little concering.
Old 08-17-2007, 04:28 PM
david vericker's Avatar
Melling oil pump with a TCI balancer.
Old 08-17-2007, 04:54 PM
Redlinez's Avatar
Volume is what's needed, not pressure, as long as it at least maintains factory pressure right?
Old 08-17-2007, 05:12 PM
DONAIMIAN's Avatar
True. A stocker is plenty for most applications.
Old 08-17-2007, 05:51 PM
JPH
JPH's Avatar
bingo.
Old 08-17-2007, 08:21 PM
bsf
bsf's Avatar
I am not going to debate you, but I always thought the solution to high LDL cholesterol levels was to increase sodium intake to raise blood pressure and keep that sludge in my blood vessels moving along.
Old 08-17-2007, 08:28 PM
98mysticZ's Avatar
i am using a tsp ported/shimmed ls6 pump
Old 08-18-2007, 05:16 PM
john563's Avatar
Is yours ported? I see them in thunder racings web site,and for an additional $75 you can get it ported.I may be swapping my cam out and thought about putting in a melling.I heard good things about them.I have aported ls6,but i figure while I'm there why not put a new pump.Ive looked at the mellings,but did not know if i would need aported version like the ones thunder offers or just a non ported melling will do fine
Old 08-18-2007, 09:53 PM
theblur98ss's Avatar
I'm using a melling as well.
Old 08-18-2007, 10:00 PM
john563's Avatar
Where did you get it,and is it ported? They have them in jegs/summit unported.Do I need aported version?
Old 08-19-2007, 05:45 PM
bad6as's Avatar
for the mellings pump users.
when you got it did you have the extra porting done?
also how does a stock ls6 pump comapre to a ported ls6 pump comared to the non ported mellings
Quick Reply: what is the best oil pump??
