Heads help.. Patriot 035 or 243 castings..
OK guys..
I am still trying to figure out all these heads stuff..
I am looking for a set of heads to run with either Patriots 226 cam or something like a custom grind..
What is the major difference in the LS6 style heads and the LS1 5.3 heads?
Do they provide different levels of power? Is on more complicated in the install?
I am going to be doing the install myself, but do not want to have to deal with a large amount of extra "make these Ls6 style heads fit" type stuff..
Is the "plug and play" of both the heads the same?
I guess that is a complicated way of saying, which heads should I pick up? the 035 casts or the 243's?
Thanks guys..
Jeff
Thanks guys..
Jeff
Originally Posted by Tram
OK guys..
Thanks guys..
Jeff
Thanks guys..
Jeff
As far as installation, they both will install with no issues. We suggest a set of the 243 CNC ported heads because of the better flow they offer. If you have anymore questions, please let us know.
