Shorty Head question
Old 09-08-2007, 06:30 AM
5PONT7's Avatar
Default Shorty Head question
On top of my Header project that I am trying to get figured out I was thinking I know that the 01-02 manifolds are said to flow alot better than the other years and I wanted to ask if it was possible to run CNC ported LS6 heads befor I got Longtubes and a Y? And if so would it also be possible to run a small cam, somewhere around a 220/240
Old 09-08-2007, 08:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The port design is not going to change from LS1, LS2, LS6....ect if that is what you are asking.
220/240 is the smallest big cam I have ever heard of!!! Hopefully you meant 220/224. Nothing wrong with running a cam like that on a stock set of LS1 heads either. That should not matter either way. Just don't get that big of a traditional split.
Old 09-08-2007, 09:39 AM
5PONT7's Avatar
i just ment will I have any flow issues by running the heads without getting headers? Like will I still get the same or close to same ammount of power gain
Old 09-08-2007, 09:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You will be shorted a little, but you will see a big improvement overall. It wont matter if you are planning to do the headers close to the same time.
Old 09-08-2007, 09:54 AM
5PONT7's Avatar
well I might just do Heads since im gona need an extra like $700 to get Headers. And I don't have a lot of patience of my own to wait a few more months of paychecks. But the ones I was planning on getting were the CNC ported heads from TSP, they are only about $1049.99
Old 09-08-2007, 05:50 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Still those are a decent head. You want a show car right? Does it have to produce power as well?
Old 09-09-2007, 12:05 AM
5PONT7's Avatar
I mean it's in show quality right now. But I want to have fun at the track and 475 HP is a number id like to one day have on the side of my car
Old 09-09-2007, 12:36 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Sounds like you need a procharger with a polished plenum.
