Oil press too high after cam/head install
Old 09-09-2007, 01:52 PM
V8RX7FTW's Avatar
Default Oil press too high after cam/head install
Press builds to over 100psi and the oil filter seal blows out. I nstalled a ported z06 oil pump trex cam z06 heads arp rod bolts. Anything I can look for on this to fix the problem? I am thinking its a oil filter issue???
Old 09-09-2007, 02:02 PM
Billy177's Avatar
sounds like you have a defective pump where the internal bypass is not working correctly. What weight oil are you using?
Old 09-09-2007, 02:04 PM
V8RX7FTW's Avatar
10 w 30 it was a brand new oil pump from speed inc. Filter is a fram oil filter. I did a quick serch and found many people on different cars ahving problems with the fram filters.
Old 09-09-2007, 02:06 PM
Billy177's Avatar
Yea definatly change that out first then go from there. I personally like K&N oil filters.
Old 09-09-2007, 03:08 PM
bczee's Avatar
Could be a stuck bypass valve/spring in the pump.
Old 09-09-2007, 03:15 PM
KRAZY K 2000 TA's Avatar
IMO its defenitly the oil pump,all i have ever run is fram filters on everything and never had a problem nor herd of anybody having a filter problem.
Old 09-09-2007, 03:38 PM
BLK02TA's Avatar
Another vote for it being the pump.
Old 09-09-2007, 04:08 PM
2000Hawk's Avatar
I agree with these guys must be the pump, i doubt it has anything to do with your oil filter. I run a K&N by the way, with Mobil 1 5W-30.
-Joel
Old 09-09-2007, 08:23 PM
V8RX7FTW's Avatar
Thanks for the input guys. I removed the oil pump to find the bypass corroded to the inside of the pump. I emailed brian at speed inc so we'll see what happens. I reinstalled the stock pump and all is well. My factory pump was in perfect shape so I told him I just want a refund. What a way to spend 5 hours taking everything back apart and my garge is a mess, oil everywhere.
Old 09-10-2007, 10:17 AM
bczee's Avatar
You lucky, usually there are more cases of the pump's bypass valve will get stuck open and leave you without any oil pressure.
