Do i need the dowel pin in my CAM?
Old 09-18-2007, 02:52 PM
The PAT WS6's Avatar
Default Do i need the dowel pin in my CAM?
im re setuping up my motor. and the dowel pin had previously fallen out and i found the dowel pin just wondering if i need to try and re install it or just use the 3 bolts to old it in.
Old 09-18-2007, 02:56 PM
LS1 Tech Administrator
Patrick G's Avatar
You'll want to re-install it. It's added insurance against bolt slippage, plus it does a good job of locating the cam sprocket onto the cam snout.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 09-18-2007, 03:06 PM
3rdgentug's Avatar
listen to this man rufus
he knows what hes talkin about
Old 09-18-2007, 03:43 PM
alright can i re-install this?! with a hammer or something? and do u think my cam is damaged pat?
Old 09-18-2007, 04:12 PM
GuitsBoy's Avatar
I would guess its some sort of press, but if it keeps falling out, hammering it in wont really help much. Might have to knurl the I/D of the pin hold in teh cam. But I would definitely use the pin for locating purposes.
Old 09-18-2007, 04:16 PM
any one else?
Old 09-18-2007, 06:00 PM
matt94z's Avatar
Take it to a machine shop, most of them will have the hardened dowels and will press them in. I did that on one of my previous cams.
Old 09-18-2007, 06:03 PM
ok. i will try that. but do yall think the cam is damaged? can i visibily tell if it is.?
Old 09-18-2007, 06:07 PM
matt94z's Avatar
Not sure without seeing it. Did the dowel break or just fall out? It shouldn't just slide in and out.
Old 09-18-2007, 06:11 PM
brad8266's Avatar
yeah you need it in there.
Old 09-18-2007, 06:54 PM
a-low's Avatar
I was in the same situation too. I took mine to a machine
shop and they pressed one on for $10 and a six pack.
Old 09-18-2007, 07:29 PM
ok i will just get it pressed back in. do yall think there is any possible damage tho?!?!?
Old 09-18-2007, 07:40 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Why are you tearing down the motor? Didn't you just put that Trex in there? Hard to say if it is damaged or not. If the pin was in when you installed it and just fell out when you set the cam sprocket aside I would wonder if a vibration from a bad spot in the cam made it pop out. I have pulled them out of stock cams before and it is a PITA with a pair of vice grips even.
Old 09-18-2007, 07:43 PM
spun a bearing on my ls1 motor- bought fully built motor- re installing the cam but just wonderin bout the dowel.
Old 09-18-2007, 08:13 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well. I guess you could get the cam doctored. That will tell you lots right there. Send it to thunder. I don't know of anywhere in the metroplex that has one.
Old 09-18-2007, 09:33 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I would have the cam checked out. You don't know if it got nicked or warped. Something might have happened to it. I wouldn't want some little part to ruin my brand new motor. You'd feel really dumb if you made two huge mistakes in a row that both cost you a motor.
