6.0 iron block
Pretty much exact, other than the alternator bracket will be missing one bolt on the left and you have to drill and tap the top right bolt hole in the block. Other than that all the sensors and covers interchange.
Thanks for responding guys! What kind of internals and heads are people running? How well would the stock rotating assembly do with a bigger cam a good set of heads and spray?
Other than drilling and tapping for the alternator, I also had to make a new mount for the driver side O2 wire hanger and there is a ground hole on the passenger side that does not exist ( that I could find) on the iron block. I had to use a motormount bolt to ground the wire.
