Cartek Stage II, G5x2 A4 dyno results
Just got my TA back from Speed inc. We dynoed 415rwhp with Cartek Stage II Heads, G5x2 Cam, SLP headers, Moser 12 bolt, Stage III Extreme trans, PY3600, along with just about every bolt on possible. No track times yet, its a vert so I hope they will let me run it. Hoping for deep 11's NA. Now we are just waiting for the NX NXL system and I should be in the 10's.
Re: Cartek Stage II, G5x2 A4 dyno results
Nice #'s for an A4, but I thought they were getting similar #'s with the G5X2 and stock LS1 heads. I would think you'd be a bit higher with the Cartek Stage-II heads.
Congrats great #'s through the A4, stall, and rearend!
BTW none of our A4 cam only cars are that high. Our best A4 cam only numbers have been 396RWHP in a C5. Two of our A4 G5X-2 cam S2 LS6 heads cars have done ~430RWHP in f-body's
how did you get that cam to fit? are your heads milled? did you have to cut valve reliefs in the pistons? I am also going to put this cam in my motor GTP Heads and ARE sort block with valve reliefs already in the pistons
