Timing Chain Slack
Timing Chain Slack
Here's my chain after 25,000. Looks like whoever had this before never changed the oil!
http://www.circuitflex.com/ChainSlack.jpg
Here's a view from the front. With the Sebring apart it makes this job cake!
http://www.circuitflex.com/FrontView.jpg
Re: Timing Chain Slack
Got my SPDC last week, putting it in tonight
Well I got the Rollmaster installed tonight. The bearing on the back fits up against the cam holder. There is no slack in the chain, and no detectable cam walk. These parts fit beautifully.
Here's a pic.
http://www.circuitflex.com/Rollmaster.jpg
Here's a pic.
The timing chain slack isnt that big of a deal guys, when you start accelerating its going to be nice and tight on the side thats pulling the gear so it really doesn't matter.
The extra slack is probably there because the crank snout may wobble a little at certain RPMS and rather than try to stretch the chain and snap it, the slack just eats it up.
I'm not an automotive engineer tho so take that with a grain of salt.
I've been told that because the block is aluminum and not iron that it will stretch more with the heat and the chain was left like that to allow for the expansion of the block....
That bit of slack on the "take up" side of the chain was making me think about the whiplash effect. I'm sure there's some built in engineering here, but would feel safer with the SDPC setup.
Chain slack reminds me of my Fix Or Repair(twice)Daily with the nylon timing gears which lost a couple of teeth one day.
Of course, this won't happen with the iron geared LS1.
