Ran the ASA cam untuned with stock manifolds at track
He he I got my first 12 second run. On the stock 16" rims and stock 245/50/16 goodyear rubber. I am pretty happy.
60' 2.192
1/8
8.519
87.477 mph
1/4
12.909
114.453 mph
60' 2.192
1/8
8.519
87.477 mph
1/4
12.909
114.453 mph
Re: Ran the ASA cam untuned with stock manifolds at track
My best before the cam and the pullies was a 13.33 at 108.9 mph at around the same 60'. But weather also played a big factor as we had a nice little tail wind around 5 mph and 68 degree weather. All my other runs were done in 90+ degree weather.
Yes DR are a must. I believe the cam traps high because I shift at 6500 rpm now with the asa and built valvetrain. And I think the ASA cam will perform alot better on stock manifolds than other cams due to is long exhuast duration.
well yes and no. those manifolds are killing you. with that much exhaust duration, you need to let that sucker breathe. you should be running low 12's if not high 11's on some traction, and a set of headers.
Yeah I agree with you. But as I am in CA and have been checked before I plan keeping the stock manifolds. Instead I just ordered a NX twin gemini nitrous kit. That should put me in the 11's and I can always put headers on later.
