View Poll Results: Nitrous or Heads?
Nitrous
6
27.27%
Heads
16
72.73%
Voters: 22. You may not vote on this poll
Nitrous or heads? And what heads?
Devil Dog, OohRah!
My current mods are (EDIT: not) in my sig. I'm looking at either a 125 shot (don't know wet or dry, that's a question for later) or a set of heads. I was thinking about the 200cc Terminator's from TSP. Any other suggestions on heads to go with this cam would be appreciated. Thanks.
Mods are: Pacesetter coated headers, TSP catted Y, Corsa cat back, Fast 90 intake manifold /NW 90 throttle body, Granatelli 85mm MAF, Meizere EWP, Powerbond underdrive pulley, K&N FIPK, 160* thermostat, Torquer V.3 231/234 .643/.598 111LSA, chromoly 7.4" pushrods, PRC gold springs, GM LS2 timing chain, ported LS6 oil pump.
heads , my friend mods Patriot Heads-Cam-Rockers Package - 59cc LS6 2.02/1.57/ , G5x3 112lsa , Partiot "Gold" .650" Lift Dual Spring Kit , Longtube Headers , Borla Catback , Meziere Electric Water Pump , LS6 manifold , 3.4 gears , 2000 camaro Z28 in the dyno 456 HP
Moderator
Get nitrous first. You'll be able to make more power with less money and it'll put you at about the max output you'd want to go on a stock bottom end LS1. That way, when you're ready for heads you can put em on a fresh shortblock (408ci?) out of the car rather than doing it with the engine in the car.
