Will stock locks work with patriot dual springs??
wow i didnt even kno certain springs used certain types of locks. that must suck if u need those special kind, and run out while installing. freakin locks can fall in the bermuta k-member pretty easily.
Closed Sponsor Account
Once again someone goes through the time and effort to install high quality dual springs, and uses STOCK LOCKS
Use PP super 7's which were designed for that application and sleep well at night!
Gunnar should be able to help you out NO problem!
Good luck!
Erik
*edit*
glad you made the wise choice
Good luck!
Erik
*edit*
