Anyone rent a pulley install tool?
Old 11-01-2007, 05:04 PM
Tram's Avatar
Default Anyone rent a pulley install tool?
Any of you guys have one you'd want to rent or loan?
Thanks
Jeff
Old 11-01-2007, 07:41 PM
021less's Avatar
Thanks
Jeff
autozone rents the removal tools, but all you need to put it back on is the old bolt!
Old 11-01-2007, 07:51 PM
oange ss's Avatar
dont use the old bolt, you'll strip the threads in the crank...check the tools section for someone sellin the homemade install tool....
Old 11-01-2007, 07:54 PM
sbw9056's Avatar
Buy a longer bolt to start the pulley, use your old bolt to seat it, then use your new bolt.
Old 11-01-2007, 08:04 PM
lastcall190's Avatar
Someone on here used to sell one. I think it was ~JOSHUA? Maybe I'm wrong...
-J
Old 11-01-2007, 08:06 PM
INMY01TA's Avatar
This guy sells the sweetest lookin install tool I've seen yet.
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html
Old 11-01-2007, 08:10 PM
vettenuts's Avatar
That's the recipe for buggered threads.
Make a tool, only takes a few minutes and is less than $20. Here's the one I made and have used on several cars. Full thread engagement ensures no damage during installation.
Old 11-01-2007, 08:13 PM
^^ Thank you. You found that length of rod at just Home Depot/Blowes? Great pic btw makes it easier than trying to draw a mental pic.
-J
Old 11-01-2007, 09:33 PM
Tram's Avatar
Yeh, where did you find the rod?
Looks like just a rod, coupla nuts, coupla washers, what's the black fella there in the middle?
Old 11-01-2007, 10:48 PM
ABQ99TA's Avatar
https://ls1tech.com/forums/showthread.php?t=391883
I have this tool if you need it I'll let you use it if you pay shipping. I works great. If you need it more than once I would just buy one it was cheap.PM me if you are interested.
Old 11-02-2007, 06:02 AM
vettenuts's Avatar
That's all it is. The black piece was a collar I had laying around that fit nicely on the rod so I used it. When I did mine, I needed a pretty tall washer stack (ATI damper) so this helped the stack height. Washers work just as well, but this saved me a trip to the hardware store.
It will engage all threads during installation, hence no thread damage at all and it is very cheap to make. Mine cost me $17 for the pieces.
Old 11-02-2007, 09:51 AM
bczee's Avatar
I recommend always using the Correct tool that is designed for the jobs.. using one off or Universal tool are not always the next best tool.
Many shops or store will rent a Balancer pull, but they are usually just 2 or 3 jaw pullers.. I would makes sure that it is designed for the GM Gen III/IV and late Chrysler. And that it is the one that uses a set of long rod to push the balancer off. The ones that is just 3 jaws and had a threaded rod and cap on it.. just seems to mess up the crank end and threads, I don't recommend just using these normal 3 jaw puller.
I know that Snap-On #YA6490 is the correct puller, I use it and it works great. And that there are a few tools on the market to hold the balancer in place while removing or installing the crank bolt (summit racing #SME-906008 is one). Many manufactors market simular tool, I highly recommend looking into these.
Old 11-02-2007, 02:30 PM
Tram's Avatar
Yeh, the Autozone "late model Chrysler Harmonic puller" worked like a champ to pull the Powerbond off..
