A couple questions on reverse split cams.
What I was wondering is, on a reverse split, is it safe to still run a good shot of N20?
If I was to get a RS cam, with a decent set of heads, that flow really well on the exhaust side, would I be fine? Or would it be best just to stick with a forward split cam?
The cam I was looking at was the 236/231 .601/.581.
Lane
Lane
Too big of a split, you could tailor VEs on a RS cam to be "friendly" on bigger shot juice.
Rule of thumb is build your setup NA and just shoot it (unless you combo a race N2O setup then you design the cam for that purpose)
