370rwhp with a t-rex is this true?
Formerly darynC-10/23/10
so i recently finished rebuilding my motor and decided to throw a t rex (+4advanced) in there and smoothed the runners on my stock heads(ls1). also plugged the EGR hole on top my manifold....
anyway i go get my car dyno'ed and after tune it gets 371rwhp and around 360rwtq... this is with full bolton's 3400 stalled th350 , STOCK 3.23 gears
+ whats listed above.
my question is what do i need to do to get this cam workin?.... are the gears really holding it back this much?
driving, i can deffinately feel a difference in power ,i just thought it would put a little more on the dyno
Usually a lower gear ratio makes you dyno less. If you put 3.73's in there its likely that its going to make less on the dyno. I definately think that it should make more power than what it did though. This was on a Dynojet? Is it falling off on the top end? Are you still on the stock intake?
Internet Mechanic
Define full bolt ons, you stated you plugged your EGR, I tend to think you have a LS1 intake manifold, not a LS6 or FAST. Do you have a U/D pulley??
Who did the tuning?
I know the ave hp loss from a m6 to a TH400 is just about 70-75 hp in a car that makes 450-500 hp, But I dont know what TH350's loss if any compared to a 4L60e.
I think your missing some stuff, the trans is possibly holding you back and either way its going to go fast due to the trans if the car's suspension is set up properly.
Who did the tuning?
bolt on= LT's/True duals,
slp 25% UD pulley,
P&P throttle body/w the bypass,
msd wires,
TR6 plugs,
lid /w k&n,
smooth bellow
took the AIR off
took the EGR and cut the little hose that sticks down in the manifold, and plugged it off
-elgin lifters
comp adj timing set
crane duals springs
TR pushrods
smoothed runners
T-rex +4advance
this was on a dyno jet with a 3400 stall going through a th350 with draglites on 26" drag radials
slp 25% UD pulley,
msd wires,
TR6 plugs,
lid /w k&n,
smooth bellow
took the AIR off
-elgin lifters
comp adj timing set
crane duals springs
TR pushrods
smoothed runners
T-rex +4advance
It will not do that well at the track, too low a stall and too low gears.
What is hurting you most in power output is the intake. also why are you running colder TR6 plugs? are you spraying? If not go back to TR55 or similar and check your tune.
What was you base output before cam change?
i plan on goin wiht a 4000 stall, and either goin 3.73 with my 26" tire or a 4.10 with a 27"
and of course a fast 90 (ported maybe) with a nick williams 90mm throttle body
