aftermarket connecting rods ?
im looking for a good strong connecting rod to be used with the stock 01 ls1 crank. what is availble and what are the prices, and part #'s. I would like to keep the rpm's around 7000 and hp all motor around 500, with a 150 wet shot MAYBE. im also going to be running my compression high around 11.5 with a domed piston (not sure which one yet) thats my next ? pistons?
Re: aftermarket connecting rods ?
I went with the Crower 6.125" rods from Scoggin-Dickey. Very nice, and only $435.
thanks
Crower 6.125 LS1 rods
i need expert info
i have a 93 camaro with a LT1 and i nee to know if any 350 crank and a set of rod will work in the LT1 because i am rebuilding it and the engine spun a bearing so it thrashed the one rod and crank and i cant find anybody that knows forsure if like a votec crank and rods will work if so please help me with the info thanks.
I have a set of Manley lightweight, they are awesome and light. No problems with engine assembly. Crower makes a good rod also, sounds good for the price of $435.
Before you buy, check the weight.
I got some Lunati Pro-Billet 6.125 rods that are up for sale. Some of the best you can buy and will really handle some serious hp. But if you're just looking for a budget set they are probably out of your price range. Eagle, Crower, Scat, and Manley are all good for the range of HP you're shooting for.
Originally Posted by parts@sdpc
Crower rods use ARP 8740 rod bolts
Originally Posted by Katech
We have Carillo I-beam 6.100 rods in stock ($206.33 ea). Katech rod bolts ($153.60/set) are FAR stronger than ARP.
Do you have any data to backup your claims on the rod bolts? How are they with stress corrosion?
Originally Posted by Wet 1
Are these SBC rods w/o the LSx offset?
LS1Tech Premium Sponsor
You might also consider the Scat rods! We have them in stock with the standard arp rod bolts & the ARP 2000 Bolt upgrades!! For the $$ they're pretty hard to beat
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Here is what we have on the shelf. Alot to choose from, so it realy depends on what you are looking for.
*Crower I beam 6.125 with ARP rod bolts ...good to 600 hp $489.95
*Scat I beam 6.125 with ARP rod bolts .......good to 650 hp $279.95
*Scat H beam 6.125 with ARP rod bolts.......good to 900 hp $449.95
*Lunati's NEW pro mod 6.125 with ARP bolts good to 950 hp $659.95
*Manley pro billet 6.125 with ARP bolts........good to 1000 hp $1,069.00
If this is going to be an everyday driver, and see the race track from time to time I would look at the Lunati pro mod's or the Scat H beam. The price is about middle of the road, and the power you say your planning to make, you will have more than enough rod. If I can help with anything please let me know!!
