Buddy wants to sell me 2002 Z06 heads, how much???
Old 06-18-2003, 06:49 PM
Screamin_Z's Avatar
Default Buddy wants to sell me 2002 Z06 heads, how much???
He works at a dealership and has a set of 2002 Z06 heads with less than 1500 miles on them. I have a 98, will they bolt directly on w/o any problems??? He wants to know a good price to sell them so I"m asking u guys, what's a good price??? Again, he's a good friend so it should be a "friend price". He also has a LS6 intake, how much for that??? same milage on it.
Old 06-18-2003, 07:08 PM
Venkman's Avatar
Default Re: Buddy wants to sell me 2002 Z06 heads, how much???
hmm...$200-250? Somewhere around there
Old 06-18-2003, 07:09 PM
Screamin_Z's Avatar
250 for the heads or the intake???
Old 06-18-2003, 07:10 PM
Screamin_Z's Avatar
and will they directly bolt onto my 98 block w/o any problems???
Old 06-18-2003, 07:12 PM
2001CamaroGuy's Avatar
perhaps $300 (they flow a little better than LS1 heads)
yes they will bolt to your block (I think you need the newer gasket though....not the 1998 version....).....but they won't use your current valve covers or coil pack holders (brackets)....you will need to get new ones (unless you get his old ones).
Old 06-18-2003, 09:18 PM
FLYNLO's Avatar
All I have to say is that if you get them under 500 bucks, you are stealing them. Check out how much they would cost OEM brand new. Also you may want to ask a TRUSTED local tuner the same question. LS6 heads are generally about the equivalent of Stage 1 LS1 heads. So that also may give you a starting point. Again, anything under 500 bucks is robbery.....but then again, I have been wrong before.
Old 06-18-2003, 09:35 PM
gator's 99TA's Avatar
if they are real LS6 heads Jer, then GO FOR IT. now just bolting them on isnt going to make a huge difference in power, but when you start doing a lot of mods (cam, headers, ls6 intake, porting, etc) then those ls6 heads will shine, esp in upper rpm.
anything under 750-1000 bucks is a GREAT deal. hell, if you dont want them, let me know, i will pick them up!
Old 06-18-2003, 09:37 PM
oh and ls6 intake are going for 300-350 bucks used. milage isnt a concern on them as they ofcourse dont wear. good luck bro!
Old 06-19-2003, 03:39 AM
Screamin_Z's Avatar
Thanks everyone, I thought 200-350 was very cheap. 500-1000 sounds better, even tho I would like to pay 300. I seen some on ebay for 1000 and knew that wasn't a "friend price". I know the intake doesn't wear, don't know why I said that. Hell, the same guy sold me a set of 315 DR nittos with 100 miles on them and one burnout for.........200. I'll tell him maybe 500.
Old 06-19-2003, 11:03 AM
Reboot's Avatar
New LS6 cores are around $1200.
Old 06-19-2003, 11:50 AM
boos2's Avatar
I don't think 2002 heads will bolt up to a 98. 98 is perimeter bolt and 2002 is center bolt. Correct? Or is that the just valve cover? I've never done it before just going by what people have said on here. But I always remeber there being a diff. between heads when people were selling them on this board.
Old 06-19-2003, 11:57 AM
Motorboater
SilverGhost's Avatar
That only applies to the valve cover design, not the head itself, the heads will bolt onto the block no problem, just need center bolt design valve covers and the right coil pack brackets,too.
Old 06-19-2003, 12:21 PM
robertbartsch's Avatar
find out what year the heads are ...2002 and newer used the lightweight sodium-filled valves and they are worth more...$300 is a steal...
..you could mill them 40 thou and get some more compression and power...just bolt them on with a new cam...
...the newer heads gaskets should work,,,
Old 06-19-2003, 12:43 PM
Screamin_Z's Avatar
Thanks everyone for their help, greatly appreciate it. I wasn't planing on putting them on without P/P and a lil bit of milling job + a cam.
Old 06-19-2003, 01:30 PM
CI_LS1's Avatar
They list 712.95 on Summit each. GM PN 12564824, from GM's website.
Old 06-19-2003, 06:01 PM
ScreaminSS01's Avatar
Do you have your dyno sheet for those bolton dynos?Those are impressive numbers
Old 06-19-2003, 07:59 PM
restoman45's Avatar
everything isnt ebay...i would never pay over 1k bucks for a set of cores....i would say under 500 is a good deal though, but 700 seems to be a "fair" price from the sets i have seen everywhere...thats just imo..
Old 06-19-2003, 10:37 PM
Screamin_Z's Avatar
I'll tell him $500 bare and see what he says
Old 06-20-2003, 09:21 AM
Bare means without valves. ...the new 2002 valves are sodium filled and are VERY pricey....
If these are 2002 heads, keep the valves...they may be fine with new springs....you said they are low mileage heads right? ...this is hard to prove, I suppose...
Old 06-20-2003, 08:35 PM
FDLS6's Avatar
Man, folks are harsh on the values.. Heads would sell for $1000 in a heartbeat, and the intake, again, instantly for $350.. You can adjust those for your "friend" rate, but those are VERY fair prices, and much less than that would be rippin' your friend.
