Am i missing any parts???
ok tell me if im missing anything! i will be doing a cam swap very soon, i have the cam, valvesprings, pushrods, oil pressure sending unit, oil pump should i get a new timing set or just the chain only??
Agreed, no need of the sending unit unless yours is broken. Get just the LS2 timing chain, pick up tube o-ring, water pump gaskets, front cover gasket/seal, and the obvious things coolant, oil, oil filter.
Get the installation kit, it comes with all of the seals and gaskets you need. And hopefully you've got the tool to swap out the springs and a puller to pull the crank pulley off.
