View Poll Results: 414cid LS2 Aluminium Stroker Long Block or Ls1 H/C
Ls1 with H/C
8
22.86%
27
77.14%
Voters: 35. You may not vote on this poll
414cid LS2 Aluminium Stroker or H/C Ls1??
I have been trying to decide for a while noe to go with a fully assembled ls2 stroker motor or go with my H/c Ls1 setup. I could get the ls2 stroker from TSP for around 8g. I currently have the TSP PRC 2.5 5.3l heads and the Ms3 cam right now. I haven't installled them yet and im trying to decide whether to go with my original plan or go with the stroker. My ls1 has about 80k miles on it right now but i want to get some good numbers put to the ground. I averaged it up and ill be spending right around 6g for all the parts i want for my Ls1 block. This car will have to be streetable and it is a m6. Any advice on which motor i should go with?
Hey man I'm in the same situation. I don't know wether to save for bigger cubes or just make it a little easier on myself and just do Heads and Cam on the stock c.i. motor
If i bought a 414cid or a 402cid shortblock, what other parts would i need to complete the block if i already have the heads, cam, intake, throttle body? Would most of the parts on my ls1 convert to the aluminum ls2 block?
I am no pro at this, I am simply offering my opinion/suggestion. I think if you sold your current setup and tried to get a better one to fit the 402 or 414 whichever you go with, the ms4 would be too small of a cam.
I think i could get a bit of money from my current heads setup, just can't decide which shrtblock to go with. 402, 408, 414? The 408 is a lot cheaper so i am kinda leaning towards it.
Ok... To go a cheaper route then the 408 low compression and a nitrous setup would work best. If you had an addtional say 3-6g you can go FI on the 408. You can do many setups on the 408 just depends on what you want to do... But if you do not plan on going forged and jsut an ls2 vs ls1 block be very careful. The LS1 block is actaully a stronger block and can withsatand the bigger numbers better. Many options out there. First is to decide the budget and go from there.
I would have to agree with this statement. Those 5.3 heads will not be enough to support 414ci. You will have to go with something bigger to let that stroker motor breath. Otherwise, the 5.3/MS3 setup would probably work better on the LS1. I probably wouldn't go with anything less than a set of 225 etp's or afr's, or maybe even a set of etp 240's.
If i got the 408, i would not be going into fi or any nitrous routes. I mainly want to go to the 408 for the torque. I am looking at getting the l92 heads with the longblocks setup. That setup should come with everything i need including cam, rockers, lifters, intake manifold, and throttle body. That way i can get rid of the fast 90/90, the 5.3s, and the ms3. Hopefully i will be satisifed with the 408. John at TSP said that i would produce good torque numbers.
yeah, you have WAYY more cubes to work with, but the thing is the install isnt JUST going to cost you 8g... you will nickel and dime it to death, just like the ls1 H/C build up... FWIW, I would just go over your budget, and priorities, and make sure everything else was in order, because the last thing you want is to build up a bad *** engine, and then limp it because you have the stock 10 bolt in it... When you build for big numbers, then you will always have to update the rest of the car to harness the new power... i would figure up a detailed plan, budget, and then add 10%...lol. Good luck. And also, I would leave the off the shelf cams right where they are, and spring for a custom grind...
