NMotion timing advance...where should I have it?
Old 12-07-2007, 04:41 PM
cpd004's Avatar
Default NMotion timing advance...where should I have it?
I have an Nmotion double roller timing chain with the advance ground on the sprocket. I'm doing a cam/heads swap and was wondering where I should have the timing mark at on the lower sprocket (the one on the crank)? Should I leave it stock '0' or raise it (+2, +4, etc.) to another setting? What would the effects be one way over the other? Any help would be appreciated.
Old 12-07-2007, 04:47 PM
JPH
JPH's Avatar
put it on 0, then degree cam, and then adavance or retard if needed.
Old 12-07-2007, 05:25 PM
cpd004's Avatar
I am using a G5X3 and there was no cam card with it. I bought this cam new. I don't know much about degreeing a cam other than what I've read, but don't I need the card in order to degree the cam?
Old 12-07-2007, 05:31 PM
JPH
JPH's Avatar
was it ground on a 112 or 114LSA?
Old 12-07-2007, 07:12 PM
cpd004's Avatar
I'll have to look through my paperwork, but I believe I have 114.
Old 12-07-2007, 07:28 PM
JPH
JPH's Avatar
well IMO, depending on where it dergrees in at, i would put the crank gear on +4, that's if ICL comes in at 114.(really should go by IVO, not ICL, but no cam card, so) The reason I say this, is because i think LG grinds are the stuff straight up, with no advance ground into them.
Old 12-08-2007, 09:23 PM
cpd004's Avatar
Ok....it is a 112 LSA. I take it I should put the chain and timing gear on set to 0 and then proceed to degree the cam correct?
Old 12-09-2007, 11:41 AM
JPH
JPH's Avatar
yes sir. that is correct.
Old 12-09-2007, 12:30 PM
cpd004's Avatar
Thanks for the great info...this will be my first time doing this...I just don't want to screw it up. Any other tips?
Old 12-09-2007, 12:35 PM
JPH
JPH's Avatar
do it twice, just to make sure it repeats the same number,and spend the time to verify TDC perfectly. good luck man.
