Anybody used the Edelbrock 2215 cam?
Building a carb'd 5.3 and wondering if there is any feedback on this cam.
It's huge adv. duration #'s worry me.
Thanks guys..
http://www.jegs.com/webapp/wcs/store...1_749097_10707
Thanks guys..
that is a small cam for gen 3 engines,, gen 3 engines are a totally different breed of engine compared to the old small block, gen 3 engines run great with high duration and still have exellent driveability were an old school small block with the same cam specs would hardly run
duration at .050 is a more constant way of measuring duration, that cam with 200/224 duration will be fine
the cam in my 6.0L(364ci) is a Comp Cams XR281HR 228/230 at .050 duration and still idles great at 850ish rpm
my brother has a 6.0L with the edelbrock 216 cam :
Duration Advertised 314° Intake/322° Exhaust
Duration @ .050'' 230° Intake/237° Exhaust
and even that cam idles great at 850-900 rpm and has great driveability
Hey guys,
It's going into a pro street studebaker lark. Should be 3200#'s or so.
I'm putting it together for a buddy and we are trying to do a real budget build on it to see how he likes it......I am a BBC guy myself and haven't messed with these too much.
Of course he is looking for a nice lopey idle but still have decent manners.
It will have about a 2500 stall or so. 3.73ish gears.
I can buy that cam new for $260.00 and it is a direct bolt in.
Unlike most all the other cams your looking at $500-600 before it's in. (more than we have in the complete engine)
I have 2 complete 5.3's with all the efi stuff if anybody wants some efi parts.
Any more suggestions appreciated.
Thanks, Brian
Thanks, Brian
Sounds like it'll be a fun car. With that cam I would go up to a 3000 converter though. I also recommend you upgrade the valve springs for that cam. Scoggin Dickey has the LS6 springs for $52.25 per set and they are a direct swap. You can find them here: http://www.sdparts.com/catalog/lsgen...veSprings.aspx
What do you guys think about the ASA cam.......I have talked with the guy and convinced him we should spend a little more money.
He is not going to want to get into much more than the LS6 springs.
And maybe a better cam.
He doesn't realize the potential of the LS engine over his 350's with a mild cam/intake combo. I talked him into doing this and want him to be impressed with the results.
Thanks, Brian
Thanks, Brian
If your not gonna do anything to bring the compression ratio up I would stay clear of any cam larger than 224/224 for the 5.3l. Most folks on the truck forum have the best results w/ the TR220(Thunder Racing), and find that going larger than that is counterproductive. But this is in a vehicle that weighs 1000 pounds more than what you are working with, which is why I say 224/224 should be your limit.
Doing some more research.......LS6 springs and maybe one of these cams?
Thnking of getting it ground on a 110lsa.
With no efi to tune, it should help get the "sound" and come into it's power pretty hard.
They all seem like they should work?
But the decriptions like....., superior top end, higher rpm power........
These are not large cams, but come with large cam descriptions?
Thanks again guys.
Brian
HYDRAULIC ROLLER-Good torque and Hyd. Hyd. 1200 to 6000 54-412-11 XR265HR 265 271 212 218 .522 .529 114°
very strong mid-range power. Good
performance cam.
HYDRAULIC ROLLER-Great mid-range Hyd. Hyd. 1300 to 6300 54-414-11 XR269HR 269 273 216 220 .525 .532 114°
with superior top end power. Needs
programmer.
HYDRAULIC ROLLER-Street/strip camshaft Hyd. Hyd. 1600 to 6600 54-416-11 XR273HR 273 277 220 224 .530 .534 112°
for high rpm power. Likes higher rocker
ratios. Must have programmer.
Thanks again guys.
Brian
performance cam.
programmer.
Well, personally I think its great! LOL, but I'm biased. Cam only plus bolt-ons put me @ 393rwhp & 383rwtq. I drive this car daily (almost 20k since the cam install) and it drives fine (tuned). Power peaks @ 6000 and carries to 6400(shift point). Makes about 360tq @ 3000rpm.
