HG thickness w/ Torquer 2 & Stock Z06 heads?
Old 01-07-2008, 12:09 PM
Cole Train's Avatar
Default HG thickness w/ Torquer 2 & Stock Z06 heads?
ok guys i'm pickin' up a Torquer v.2 and have unmilled Z06 heads going with it. My question is will a .040 gasket work and have good PTV clearance still? the reason i ask is this would help to bump up the compression. Should i do that or just stay with stock gaskets? Also are stock length pushrods ok for this cam?~Cole~
Old 01-07-2008, 12:24 PM
KONG's Avatar
.040 Cometic headgasket is perfect with those heads plus it will improve quench and give a "slight" raise in compression.
You should buy a pushrod length checker before you try and guess a pushrod length. This will save you a headache and some money. Good Luck.
Old 01-07-2008, 12:32 PM
PREDATOR-Z's Avatar
What LSA and ICL?
Old 01-07-2008, 02:30 PM
Cole Train's Avatar
112 LSA is what i was gonna go for. ICL i'm not sure what that abbreviation is for, sorry well i'm hoping a stock length rod is ok i have a set sitting waiting to go in Thanks for clearing up what ICL means in advanced Predator i appreciate it~Cole~
Old 01-08-2008, 04:49 AM
Cole Train's Avatar
bumpity...
Old 01-08-2008, 11:46 AM
PREDATOR-Z's Avatar
ICL is intake centerline or LSA - advance in grind
like 112+2 (110 ICL)or 112 +4 (108 ICL),
you could run a 112+2 with .040 with good PTV, but + 4 might be pushing it.
If you have a 112+4 you can always retard it 2* via an adjustable chain FYI.
Old 01-08-2008, 01:40 PM
Cole Train's Avatar
ah i did know thathaha well i will talk with TSP and see about that. I'd go with a 112+2 just to make sure i'm not pushin' it. Appreciate the help man.~Cole~
