Dart heads rev em how hard?
I have a new set of Dart 225's on my motor and will be camming it soon. How hard are you guys revving these springs to? I want to set the rev limit up to a safe limit, i have a soft and hard cut facility on my ECU, i had the cam custom ground and shift point should be 6600, with a redline of 6800. Can they handle this ok?
Had a cam specced for me 232/236 .625/.629, its being ground to run with my 1.85 rockers, so this is how it pans out at the valve end. I also noticed on the spec sheet it is XE lobes, easier time for my valvegear i assume with the higher ratio rockers. No bad thing. Just wondering what you can safely rev these to. I know theres no point going way past peak.
I think you better run some numbers and measure your installed height. Those springs are excellent, but they are installed at approximately 1.765" (from memory) so I think you may hit or be close to coil bind with that cam. The springs will keep up with most any cam, but if you bottom them that's another issue. With that stout a setup, you may need something like a set of Crane 833's, which have a high seat value and more stiffness.
I shall check when installed to be safe, ihad the the valves cut back in the head by 0.030 cos i was paranoid about PTV, so a bit more there too. But i will double check.
The springs on the Darts are excellent springs, but based on your setup you really need to measure and figure it out. I put my setup into a spreadsheet to see the seat numbers and clearances with my setup. Since you have recessed the valves, you may find your seat values are very low since these springs don't have a lot of seat pressure at 1.8 and you are more than 1.8 you may already have an issue. I would take some measurements on the work bench prior to installation, its a heck of a lot easier.
LS1511ML Beehive
OD - 1.290"
ID - .630"
Seat Pressure - 120lbs@1.800
Over the nose - 360lbs@1.175
Rate - 384
Max lift - .625"
Coil Bind - 1.100"
So at 1.800" installed height with the cam you plan on running, you will have an issue.
Looking at the PSI specs for the LS1511, I was incorrect. The specs for these springs are as follows:
LS1511ML Beehive
OD - 1.290"
ID - .630"
Rate - 384
Max lift - .625"
Coil Bind - 1.100"
LS1511ML Beehive
OD - 1.290"
ID - .630"
Rate - 384
Max lift - .625"
Coil Bind - 1.100"
Its never simple is it!? I did a search on these springs and there was a guy running these on an LS7 and running .650 lift. I should tell him he's on thin ice too!!
1.800 Installed height - .060 minimum spring clearance = 1.740 safe installed height
1.740 safe installed height - 1.100 coil bind = .640 max lift
It seems that PSI specifies more clearance for safety.
Last edited by 405HP_Z06; 01-09-2008 at 08:27 PM. Reason: Minimum coil clearance error
So would you say if my install is 1.800 or slightly more i can run them? I searched and found that Katech runs these to 7100rpm with .650 lift, install to suit obviously.
IF the valves have been cut back by 0.030 as my vendor says they have ( will measure to be sure.) then ok? Can you buy a valve spring tool and if what sort of money are they? Thanks
http://store.summitracing.com/egnsea...115+4294853226
You need the mic that measures 1.600" - 2.100"
