Is this headbolt important?
The short headbolt on the end of the head will not tq down more than 30ftlbs. Its actually an ARP stud but you get the point. I did the GM thread repair kit and it just wants to pull the thread insert back up. It just does not have enough bite it seems like. I call TSP and they tell me that because im not running a high compression setup and not spraying but more than a 100 shot I should be okay w/o tq'ing that nut down on the stud all the way. I really dont want to just leave it like it is and cross my fingers but then again they build alot of stuff. Then the question is what can I do next? Does helicoil make something that works on our LSX motors? Its just a shallow hole so something really long is not needed. At this point I really just want to find a way to bolt something down and have it tq'ed to atleast 70ftlbs like the rest. Whats your guys input?
You need to fix it, you will end up leaking over time. While its apart, correct it. Is the insert sliding out when you load it?
You could contact ARP, you may be able to get a larger stud but it will need to be necked to attain the correct stretch but you need to explain the situation to their lead tech guy, not the people who just answer the phone as they will likely need to run a few calcs to sort out what to do. I would not personally re-assemble with this condition. There are also other inserts you can get such as a Keensert, you might look into those but they require a larger hole for installation.
If you have a good local machine shop (does not need to be car shop) have them drill and tap the block to a bigger size, like 9/16 13. Then buy a 2 inch long 9/16 bolt and cut the head off. Loctite whats left in so it is below deck, then drill and tap the bolt for the stock 11mm head thread. You will not pull this repair.
Kurt
Kurt
www.mcmaster.com they have just about every thing you need for this situation. You might be able to find what you need at a machine shop for a better price though.
I did use the gm timesert kit, correctly. I have done this before so it was not my first time. It will just breaked the thread insert in half after putting around 50ftlbs of tq on it. I DO NOT want to pull the motor, its an easy hole to get to.
