SLP heavy duty oil pump
so im doin the h/c swap while im in there im puttin some headers on and im going to put a slp heavy duty oil pump in what oil should i use should i use a heavier oil beings its a heavy duty pump?
so this pump is made to run factory pressure or i can change the spring and it will increase 5psi under high rpm so should i leave it stock or more pressure i heard more pressure will decrease hp?
You are about where I am then OP wise. I like better OP as my 99 Z-71 truck with 175k idles what my LS1 runs at 2k rpm (45 psi) but there are many vaiables. We are both well within the safe zone so I don't think too much about it though I wish my ls1 idled 45psi (70k miles on T/A vs. 175k on truck) and ran 55psi like my truck at 1500rpm but it doesn't matter, lots of variables. You (we) are both ok and well within healthy specs so just keep your oil changed and it will last a long time!!!!!!
