H/C parts install list (long post)
2000 Trans Am Proposed mod list:
I am considering these items from WS6 Store. They seem to have everything I need in one place. This car is for the most part a father/son project. We take it to cruises and car shows, and we enjoy hitting the gas pedal at the dragstrip every once and a while. We are on a budget of 6-7K. Our goal is to make reliable power in the 420-440 hp range. A more aggressive than stock idle (not lopey), and aggressive exhaust is a must. We like the sound of the current Loudmouth catback exhaust.
We have done some research and believe these parts will meet our goals. If you see anything missing or any changes that need to be made please let me know.
Heads: Patriot Stage 2 59cc (Should be around a 11.5:1 compression. Is flycutting required?)
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=1185{6}528&osCsid=196 45c4e65ea25bd15552aa5b16af9af
Cam : 98-02 LS1 Comp Cams "Custom Grind" Cam, 224/224 580/580 114 LSA (Looking around a stock sound, but want it to still sound cool)
http://www.ws6project.com/user_stor/...552aa5b16af9af
Roller lifters: 98-02 Comp Cams High Energy Hydraulic Roller Lifters
Pushrods: (We'll measure for the right length) Comp Cams Hi-Tech One-Piece Chromemoly pushrods, 7.400" Stock LS
Rockers: 98-02 LS1 Harland Sharp Roller Rockers - 1.7 Non-Adj
Gaskets, bolts, seals, ect: 98-02 LS1 SLP Head/Camshaft Installation Kit (12504)
Comes with: Head gaskets, Intake gasket, Engine coolant block off seals, EGR gasket, AIR gaskets, Valve cover gaskets, Timing cover gasket, exhaust manifold gaskets, Head bolts, and a front oil seal.
Fuel Injectors: Accel Performance Fuel Injectors 36LB
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=1137{6}495&osCsid=196 45c4e65ea25bd15552aa5b16af9af
Fuel Filter: 93-02 GM In-Line Fuel Filter
Fuel System: LS1 F-Body (Plastic) Racetronix Fuel System
Oil Pump and Chain (package): 98-02 LS1 SLP Heavy Duty Oil Pump/Timing Chain Package
Oil Pump, 1997-03 LS1/LS6 Heavy-Duty
Timing Chain, 1997-03 LS1/LS6 Double-Roller
U/D pulley: LS1 ASP Racing 25% Underdrive Crank Pulley (comes with crank bolt)
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=963{6}651&osCsid=1964 5c4e65ea25bd15552aa5b16af9af
Headders: QTP #200198 F Body LS1 1 3/4 High Velocity Long Tube Header (no AIR or EGR)
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=1183{6}691&osCsid=196 45c4e65ea25bd15552aa5b16af9af
Y pipe: 2000 LS1 QTP Off-Road Y-Pipe w/Dual QTEC Cutouts (no cats)
O2 Sensors: LS1 O2 Sensor Simulators
Header Bolts: LS1 Stage 8 Locking Header Bolts
Cutout Electronics: Quick Time Performance Electric Cutout Controller
Catback: Magnaflow # 15684 5.7L V8, Trans-Am/WS-6/Firehawk,
rear exit, 3"/2.5" SS tubing, 3.5" slash/p-SS tip
Drive Shaft loop: Lakewood Driveshaft Safety Loop
Dyno tune
The target date for installation is March, right now I am getting all of the research done. Thanks in advance!
-Mark and Ernie
Dyno tune
-Mark and Ernie
arp cam retainer bolts
arp crank bolt
arp head studs
arp header studs stainless
make sure headers are stainless
Have a custom y pipe made with a flowmaster D-port merge and tuck it up as high as possible and use stainless band style clamps
Heads and cam will be choked without intake, tb ,lid ect
I like the melling pump best one out their, and the crane double roller is nice a bit $ at 209 campared to others but worth it.
I would have a custom cam speced. and stock rockers would work fine.
How i would do it anyway. if i could redue it, i would have just sprayed the car and saved for other stuff like built trans rearend and suspinshion.
arp crank bolt
arp head studs
you could get stuff a lot cheaper from other places like texas speed, most slp stuff seems overpriced to me...example: slp oil pump/timing chain - $314 tsp ported pump and ls2 timing set - $240. just to save you some money...
also stock rockers should be fine and you wouldn't have to upgrade lifters if you didn't want to...they should be fine also. or ls7 or caddy lifters would save you some money
