which underdriven pulley ?
Old 01-17-2008, 02:25 PM
04gtod's Avatar
Default which underdriven pulley ?
Wanted a recommendation for UD pulley. ASP,SLP,ATI? What do you run and are you happy with it ?
Old 01-17-2008, 02:28 PM
BLACK2001SS's Avatar
I have March but slp is the same I think march is cheeper.
Old 01-17-2008, 03:01 PM
SOMbitch's Avatar
I don't think they are the same. March is a fluid dampened pully and SLP is not. SLP is also 25% underdrive and March 10%. March is a nice piece.
Old 01-17-2008, 03:15 PM
04gtod's Avatar
I just wanted the non fluid dampened kind.
Old 01-17-2008, 04:07 PM
StangSlayerSS's Avatar
I had the march and it is a great piece just a pain to get off
Old 01-17-2008, 04:12 PM
Brads LS1 02Z's Avatar
i went with the ASP sense you can get a alt. pullie to go along with it...
Old 01-17-2008, 04:34 PM
March Performance Pulley systems are designed to increase horsepower by reducing accessory drag on your motor. March's new LS1 dampener pulley has a fluid based center, which will not cause spark sensors to retard timing with resultant loss of power. These pulleys have been dyno tested at 12 hp gain and are SFI approved. A new harmonic balancer bolt is included and the two required belts are listed below.
SLP's new 25% underdrive balancer for LS1/LS6/LS2 Corvette's incorporates a number of high-quality features you won't find on any other aftermarket unit. Chief among them are a pair of extra-tall belt-retention walls that eliminate the belt-slippage issues common to other balancers (see photo). Gains of up to 10 horsepower can be expected. Other unique design strengths include 100% steel construction (other brands use steel and aluminum), integral timing marks, and built-in puller-mounting threads. Includes a new balancer bolt and detailed installation instructions.
And I have the SLP one.
Old 01-17-2008, 04:41 PM
KILLERARMY's Avatar
SLP here.
Old 01-17-2008, 05:17 PM
DaveX's Avatar
The march is 25% underdrive just like all the rest of them. Mine has been fine so far and appears to be made well and I'm not having any problems with the belt coming off.
Old 01-17-2008, 06:54 PM
Moderator
davered00ss's Avatar
I have the SLP and it works great.
Old 01-17-2008, 07:54 PM
LS1MCSS's Avatar
They aren't all 25%. Jegs has one that's only 10%.
Old 01-17-2008, 08:05 PM
418redz28's Avatar
im happy with the asp. no issues at all.
TXZ28LS1's Avatar
im goin with SLP!
Old 01-17-2008, 08:16 PM
DaveX's Avatar
Hmm I've never seen one at 10%. But I don't doubt you. Is that a march? I see they have 2 for the LS1 but it doesn't say what % under they are. Actually they look the same but it looks like one comes with the alternater pulley also. The march I bought from Thunder is 25% under. 10% wouldn't be worth doing.
Old 01-17-2008, 08:17 PM
jzzamesb's Avatar
I've always heard powerbond makes the slp pulley..
Old 01-17-2008, 11:35 PM
EndlessSummer85's Avatar
I'm running a powerbond no probs with it. No charging issues or anything like that.
Old 01-18-2008, 12:11 AM
Gun5's Avatar
i want to buy the powerbond but if its gonna slip a belt would rather get SLP
Old 01-18-2008, 12:16 AM
rickyracer25's Avatar
asp here i'm happy
Old 01-18-2008, 08:07 AM
04gtod's Avatar
Thanks for the input guys.
Old 01-18-2008, 08:12 AM
Kleeborp the Moderator™
MeentSS02's Avatar
You can get their alternator pulley separately in either overdrive or underdrive. I actually use their underdrive alternator pulley with my setup...
I had a Powerbond 25% UD, and now run a full sized ATI Superdamper.
