Is this a rod knock? Video
Old 02-02-2008, 07:11 PM
mvvette97's Avatar
Default Is this a rod knock? Video
sounds like **** to me but what do you guys think this is?
[IMG][/IMG]
Old 02-02-2008, 07:13 PM
bearcatt's Avatar
Sounds more like a fan hitting a shroud.
Old 02-02-2008, 07:17 PM
mvvette97's Avatar
I'm sure it's not the fans. It's coming from the engine. It's so loud I can't tell where exactly it's coming from. Mostly the center
Old 02-02-2008, 07:30 PM
badass99ss's Avatar
Try a stethoscope, it might help you locate it. My buddy had some piston slap and we located it to a specific cylinder.
Old 02-02-2008, 07:56 PM
5.3LJimmy's Avatar
Sounds like it's coming from the top end/lifter to me, but it's always hard to judge from a video. If you had a rod knock that bad you would have lots of shavings in your oil.
Old 02-02-2008, 08:03 PM
Soul TKR's Avatar
that definately sounds like rod nock... the "clunking" at least that I heard slightly in the begginning of the video...
the tapping noise sounds more like a valve or something hitting the pistons...
I recentley just spun a bearing and had some rod knock coming from the center. It sounded JUST like that... cept i didn't have the tapping noise that you have... So i'm thinking you have a couple problems... not just the one...
once we pulled my engine, we found out not only did i have a spun bearing, but all my valves hit all my pistons as well... which i would think would make that noise we are hearing in your video...
keep us updated
P.S. my engine eventually started shaking really bad after a few dyno runs as well... like once it got heated up real well from some abuse... but contrary to what 5.3Jimmy said, I didn't have any shavings in my oil at all...
Old 02-02-2008, 08:43 PM
SladeX's Avatar
Damn that sounds nasty... it's not valvetrain noise that's for sure.
Old 02-02-2008, 08:51 PM
98TA_vert's Avatar
sounds like the bottom end rattle of death to me, exactly like my buddies car when he spun his rod bearing
Old 02-02-2008, 09:14 PM
mvvette97's Avatar
This isn't my car, we just took the video of it while it was still on the trailer. I also think it's a rod. It sounds really deep down in the engine. I guess the owner thought it was a pushrod so he put new pushrods in. I told him that I think we need to pull the K member and drop the pan so I'll see what he wants to do..
